FOR code in KUKA
  • mhanbildiren
  • August 28, 2020 at 4:36 PM
  • mhanbildiren
    Hello, i have products it seems straight metal sheet their heights are 5mm, i have box which has this metal sheets, i want TL get sheets and put the other area, i will repeat this 1000 10.000 times maybe.
    Top of product's height from the ground is 1000mm, this sheets Putted on Top on each other so lower sheet's height from the ground is nearly 10mm
    How can i do robot's pick point get lower per lap?
    Probably i have to use for loop but how?
    **İ know the long way is typing 1.000.000 lime codes but what is shortcut?:thinking_face:
  • spiral
    146
    • August 28, 2020 at 5:45 PM
    For this is better to use interrupt.You can trigger the interrupt with sensor on the gripper that detects the metal sheet.
    SkyeFire
    1,051
    9,426
    • August 28, 2020 at 5:48 PM
    This is pretty simple. This example assumes you have hand-taught the Pick position for the top item in the stack, in Base 1, with the Base's -Z axis pointing down. The variable rPartThickness is assumed to be set to how thick each sheet metal sheet is.
    DECL _nCounter
    DECL FRAME _fShift
    FOR _nCounter = 0 TO 10000
      $BASE = BASE_DATA[1] ; make sure "above Pick" motion is not affected by FOR
      PTP XPick : {X 0,Y 0,Z 100,A 0,B 0,C 0} C_PTP ; move to approach point 100mm above highest pick
      _fShift = $NULLFRAME ; set to all 0s
      _fShift.Z = (0-_nCounter) * rPartThickness; convert counter value into a negative Z shift
      $BASE = BASE_DATA[1] : _fShift ; move the Base
      LIN XPick
      ; activate gripper here
      $BASE = BASE_DATA[1] ; reset Base to original value
       LIN XPick : {X 0,Y 0,Z 100,A 0,B 0,C 0} C_PTP ; move to depart point 100mm above highest pick
       ; Move to dropoff position, drop sheet, etc
    ENDFOR
    However, a FOR loop may not be a good way to do this -- everything has to be inside the loop, including your moves over to the Dropoff area. A better way would be to use a counter variable, and increase it by 1 every time you pick a sheet. Then your Pick routine and Drop routine (and other routines, like Move Home, Move To Maintenance, etc) can be separated.
    panic mode
    1,280
    13,082
    • August 28, 2020 at 5:52 PM
    Quote from mhanbildiren
    shortcut to typing 1000000 lines of code is reading 300 page manual :winking_face:
    if you are sure of product thickness and tight tolerances, you may compute pick point as you go - one per pick... or calculate all of them before you start.
    but while this can work, it is very inflexible without feedback.
    for calculation look up geometric operator or palletizer code samples
    for feedback, lookup up search with interrupt (RESUME command)
  • mhanbildiren
    • August 28, 2020 at 6:10 PM
    Quote from panic mode
    I only need this example, How can i do? What i need about code statement?
    Ground to sheet height:
    1000mm
    Pick
    Process..
    995mm
    Pick
    Proces..
    990mm
    Pick
    Process..
    985mm
    Pick
    Process..
    980mm
    Pick
    Process
    10mm
    Pick
    Process..
    5mm
    Pick
    Process..
    END
    panic mode
    1,280
    13,082
    • August 28, 2020 at 6:23 PM
    DEF MAIN)
    DECL INT n
    PTP HOME VEL 100% DEFAULT ....
    FOR n=1000 TO 5 STEP -5
       Pick(n)
       Process()
    ENDFOR
    END
    DEF Pick(height:in)
      DECL INT height
      DECL E6Pos PickPos, StartPos
      BAS(#tool,1) ; gripper
      BAS(#base,3) ; whatever
      StartPos=$PosAct
      PickPos = xPickPos
      PickPos.Z=height
      LIN PickPos
      GripperClose()
      LIN StartPos
    END
    DEF Process()
      WAIT SEC 5
    END
  • mhanbildiren
    • August 29, 2020 at 6:55 PM
    DEF MAIN)
    DECL INT n
       Pick(n)
       Process()
    ENDFOR
    END
    DEF Pick(height:in)
      DECL INT height
      StartPos=$PosAct
      PickPos = xPickPos
      PickPos.Z=height
      LIN PickPos
      GripperClose()
      LIN StartPos
    END
    DEF Process()
      WAIT SEC 5
    END
    thank you i will try
  • Y105657LL
    35
    • September 2, 2020 at 9:38 AM
    Oh...this is too much products and difference. I used to work in a project that's up to 10 unstable roofs with one gripper.at first,I've tried to use forloop with num=num -1 .but it was a changed num..it was damn to teach operator to change the num.sol used interrupt.trigger with part sensor.but it didn't work well as l imagine .you know it can't run farst oR it will occur bad collision...so l set the OV =5%:neutral_face::neutral_face:...maybe you could ref my bad exp:tired_face:
  • spiral
    146
    • September 2, 2020 at 9:52 AM
    You can put one laser sensor on the gripper that detects the part at a distance and use interrupt to reduce the speed for the last 100mm maybe.
Similar Threads
  • BRAKE, RESUME, continues path and RESUME point
    • saeid ss
    • August 20, 2020 at 11:36 AM
    • KUKA Robot Forum
  • Is it OK to maintain KUKA code on git?
    • s2007.ravi
    • February 8, 2020 at 5:14 AM
    • KUKA Robot Forum
  • How can I integrate the g code into krl?
    • ardobebe
    • July 12, 2018 at 8:57 AM
    • KUKA Robot Forum
  • cant start kuka vkr 200/2 to run program
    • danao
    • August 10, 2020 at 11:48 AM
    • KUKA Robot Forum
  • Kuka signal input assigned program lines
    • smc
    • August 20, 2020 at 7:22 PM
    • KUKA Robot Forum
  • Optimizing my submit program
    • Vaibhav Shah
    • October 23, 2019 at 9:51 AM
    • KUKA Robot Forum
  • Serial Communication (PC -> KUKA KRC2 5.2)
    • Guedes24
    • July 10, 2019 at 2:47 PM
    • KUKA Robot Forum
  • For
