Does anyone know how to format the CF card on a DX100?
Thanks.
Thanks.
Have not seen that ability since the XRC.
I want to do it on a DX100
You can go to DX100 windows OS and format your CF card that installed on the pendant.
I already did this and it doesn't work. Fat, fat32, ntfs does not work in XRC. I want to format it so that it is recognized by XRC.
You need an old camera that takes CF cards. Format it in the camera and the XRC will work.
Please remember most XRC robots only take up to a 32meg size. Some will take up to 64meg, but nothing higher.
Necesita una cámara antigua que admita tarjetas CF. Formatee en la cámara y el XRC funcionará.
Recuerde que la mayoría de los robots XRC solo tienen un tamaño de 32 meg. Algunos tomarán hasta 64meg, pero nada más.
There is no way to do it with DX100?
Now I am really confused, you first asked about formatting on DX100, but then tell us it is for XRC. So do you have the XRC controller also? If so, format it in the XRC controller and be done.
Ahora estoy realmente confundido, primero preguntaste sobre el formateo en DX100, pero luego nos dices que es para XRC. Entonces, ¿tienes el controlador XRC también? Si es así, formatéelo en el controlador XRC y listo.
Sorry, I did not explain well. I have XRC and dx100 controllers. XRC does not read my card and does not allow me to format. So I ask how to format in dx100 if it reads the card. Sorry for my words too. I'm Spanish and I'm not fluent in English
So the size of the card is too big?
32 mb y 128mb.
Well Robodoc said most up to 32, some maybe 64, so the 128 is definitely out. Maybe you can try to find a 16? Or maybe the card reader is bad on the XRC that you are trying to use. Have you other XRC controllers? Try another one.
Yes, I have 3 XRC controllers, 1 dx100. In XRC they don't work. only in dx100. I'll try the old camera. I believed that somehow it could be formatted with dx100.
When I try to load I get error 3080
Okay, now that we know the whole story, try this.
Put your 128meg card in a PC and do these commands;
Your 128meg card is now 32meg. You will have to format it in a camera. If it still does not work the CF card you have is uncompatable with the XRC controller.
Ok, Thanks.
I tested CF card with 128 and 256 meg in XRC and it worked.
What card model?
