Hello all,
I was making a program in MotoSim.
When I move the cursor to a line, then press EDIT I can't find the COPY instruction in Virtual teach pendant.
May anyone help me, thanks.
Hello all,
Need to be on the Instruction side (right side) of the job. Press and hold either of the SHIFT keys. Press SELECT. You should get a blue highlight on the Address side (left side). Cursor up or down if multiple lines are to be copied. Go up to EDIT in the Menu area.
Make sure you select a range of steps first on the INSTRUCTION side by using SHIFT-SELECT. Then COPY will show up under EDIT.
