Torchmate 3 Fanuc
  • sanjay bisht
  • August 20, 2020 at 2:23 PM
  • sanjay bisht
    85
    I am confused about what is torchmate for ??
    I have setup torchmate for one of my TCP - too frame.
    I mastered it..
    then ran the TM_ADJST program which calls SET_ATCP
    It started giving me the X Y variation for each run, whenever IT PASSES the program ( I have set variation to 1mm) - You can see that on the right side window under DATA torchmate
    BUT WHENEVER IT FAILS , IT SAYS ----- TMAT -000 Offset is out of range - which mean it failed
    Then it gives there options - on the left side... for fail cycles there is no Data under - DATA torchmate
    What to do after this...
    Whenever i go to option 1 and SHIFT FORWARD-- it says program is running, but nothing happens.
    I was thinking torchmate cahnges the TCP frame values automatically , how to do that??
    Or It is only to see those variation in DATA, nothing else, its not for auto updating or adjusting TCP???
    Pls answer
  • CSaunders
    44
    • August 20, 2020 at 7:13 PM
    Quote from sanjay bisht
    Pls answer
    Torchmate adjusts the tool frame each time TM_Adjust is executed. If you see variation after running torchmate several times concurrently, I would assume you aren't using the correct tool frame or something else is configured incorrect.
  • sanjay bisht
    85
    • August 21, 2020 at 6:20 AM
    Whenever it adjusts the TCP, you mean i will see the TOOL Frame Values changed after TM AJST is executed?
    I am not seeing any change in the TOOL Frame values in Setup-Frames window, so i dont know if its adjusting or not
Similar Threads
  • Fanuc Torchmate 3 Query
    • sanjay bisht
    • August 11, 2020 at 6:21 AM
    • Fanuc Robot Forum
  • RJ3 DNP/DN3 DNET no lights on power up
    • aarond
    • April 20, 2019 at 4:44 PM
    • Fanuc Robot Forum
  • Fanuc touch sense to skip welds
    • frosty101
    • April 20, 2018 at 3:04 PM
    • Fanuc Robot Forum
  • TCP Correction in 120IB(R-J3IB) Fanuc Robot
    • bidhan
    • February 6, 2018 at 4:00 AM
    • Fanuc Robot Forum
  • Torchmate
    • WD-Weldtech
    • October 25, 2017 at 5:09 PM
    • Fanuc Robot Forum
