hey, guys,
i got a problem about laser sensor connection using ethernet. following the manual, i set up TCP/IP and client tag in host comm, and call a karel program to turn on/off the sesnor which is working well. however, when i try to use sensor on[1] command in TP program, the sensor does not response. is there anything need to be defined additionally?
best regards,
Chen
