Prevent movement in certain directions
  • robocoder
  • August 13, 2020 at 8:21 AM
  • robocoder
    5
    51
    Hi!
    Is there a way to prevent the robot from moving in certain directions when programming touch-ups with the hand controller in T1?
    eg. I only want the joystick to be able to move the robot in Y and Z direction. I want to lock the x-direction where the robot currently is and in the z-direction I only want to be able to move stright up or down (currently using palletize mode for this).
    Thanks! :smiling_face:
  • Go to Best Answer
  • Mentat
    61
    5
    243
    • August 13, 2020 at 10:53 AM
    Don't know anything for such purpose directly. I suppose one could check if the new touched up value is offset in the right/allowed direction and if not, rewrite it back to old value and inform the user with a message box.
    Fubini
    278
    1,893
    • August 13, 2020 at 11:27 AM
    • Best Answer
    Using $Cart_mask and $axis_Mask in r1/$machine.dat would prevent showing up jogging components permanently. Requires a reboot if I remember correctly. But I do not know if this is feasable for you or you need a temporary solution.
    Fubini
  • robocoder
    5
    51
    • August 16, 2020 at 5:30 PM
    I'll have to think about something else :smiling_face: Thanks for the tips anyway! :smiling_face:
  • panic mode
    1,281
    13,091
    • August 16, 2020 at 6:28 PM
    this is a joystick? can you not make sure that only desired axes are wired / programmed?
  • robocoder
    5
    51
    • August 16, 2020 at 6:34 PM
    Yes, it is when using the joystick. I want the robot to go to the desired x and z location, then make the operator only be able to move in the y-direction before making a touchup point.
  • panic mode
    1,281
    13,091
    • August 16, 2020 at 6:36 PM
    somehow i still believe you are calling 6D mouse a "joystick". in other words you are referring to feature of KCP not external device
  • robocoder
    5
    51
    • August 16, 2020 at 6:38 PM
    You are correct sir! I meant 6D mouse
  • Mentat
    61
    5
    243
    • August 17, 2020 at 10:25 AM
    Quote from robocoder
    You guys are using 6D mouse... on purpose? :O
  • robocoder
    5
    51
    • August 24, 2020 at 2:15 PM
    Mentat, I am not sure how to respond to that :p
  • panic mode
    1,281
    13,091
    • August 24, 2020 at 2:55 PM
    • #11
    :grinning_squinting_face:
  • movement
