I try to use the real time clock to show to take data every hour.
But I have the fault invalid parameter.
I wrote it $SYS_TIME.$HOUR
Do I need to activate something?
did you check this parameter in your system variables? I found that they removed this variables from the list in newer robot software versions.
Didn't found it on the menu - system - variable
You can use this variable instead
$system_time[1].pwr_tot
it will give you the number of minutes that the controller has been powered on, it its lifetime.
Simple set a register = to this value then wait for 60 minutes to elapse.
thanks!
