About Fanuc timer accuracy
  • Hello,everyone
    I'm running a program and I want to get the running time. Now,I use a timer to reset ,start and stop ,then R[1]=time1; but I find the timer value is wrong when the program perform the end.The timer value is 200 second, but when I use my phone to timing the running time,the value is 156 actually ,I don't know where is wrong ,I am not sure how to deal with it ? And is there any other way to solve this problem. Please help...
  • HawkME
    Changed the title of the thread from “About funac timer accuracy” to “About Fanuc timer accuracy”.
  • On my experience, this method You described always worked well.
    When You say about this 200 sec result, are you referring to TIMER[1] value, or to R[1] value? Botha are 200 sec?
    Maybe something more writing a value on R[1]?
  • Here's the program I wrote
    TIMER[1]=reset;
    TIMER[1]=start;
    TIMER[1]=stop;
    R[1]=TIMER[1]
    when the program end the TP screen display R[1] = 200 ,
    but I timed it on my phone 156 sec from start to finish.There is no other to use R[1] ,why is this?
  • How did you time it on your phone? Are you sure you didn't press the button on your phone at a different time than the code executed?
    That isn't enough evidence to say the timer is wrong.
  • Just click on the run program and the phone starts ticking , I press the button on my phone at the same time when the code start executed,and when TP display stop I press stop on my phone.The difference should be small between the two results ,but that's a huge error.
  • The ‘‘Elapsed Simulation Time‘’ in run panel means the time real robot running the same program,
    and the time in profiler means the time simulating the program,is right?
