  4. ABB Robot Forum
copy file to FTP site via RAPID IRC5
  • Ruud
  • August 6, 2020 at 8:56 AM
  • Ruud
    I am facing an issue using FTP with my IRC5 (robotware 5.15) system.
    I want to copy files from the robotcontroller to the external FTP site (PC:/). The FTP server is UP (event msg 10076).
    When using the flexpendant --> flexpendant explorer I am able to copy the file from the home directory and past it on the PC:/. Creating a backup from the flexpendant to PC:/ is also without a problem.
    The problem occurs when I am trying to copy the file to the PC:/ with a rapid command:
    VAR string filename_PC:="PC:/bar1.txt";
    VAR string filename_robot:="HOME:/PRODUCT1/bar100.txt";
    !copy file
    CopyFile filename_PC,filename_robot;
    The error generated is "File Access Error" 40548.
    In this case I tried to copy a file from PC: to HOME:. The other way around gives the same error.
    So: there are no problems with reading/writing the ftp site from the flexpendant explorer but when using RAPID code it will not work.
    Does anyone has a clue how to solve this??
    KR Ruud
  • hermann
    404
    2,595
    • August 6, 2020 at 8:54 PM
    May be if the target file already exists you have to delete it before copying the new one.
  • neel
    92
    • November 24, 2021 at 6:52 PM
    Hello Team,
    Can someone help me..
    In my upcoming project Customer has one Line PC and in that 10 robots are connected IP of line PC is 192.168.16.XX.
    Customer requirement is they will press backup and the backup will save in that Line PC in a particular folder.
    In robot we "FTP/NFS client option" and "PC Interface option" too.
    Please help me I'm new to Network programming.
    Br/Neel
  • SomeTekk
    16
    201
    • November 24, 2021 at 7:18 PM
    Which version of RW is it?
    In any case you will need to consult the parameter (I/O System) for the system input Backup, and (Communication) for Application Protocol.
    See the documentation in RobotStudio under the File tab in the Help section.
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • November 24, 2021 at 7:33 PM
    Since you have PC interface, with robotstudio installed on the line PC it could get backups scheduled automatically.
  • neel
    92
    • November 25, 2021 at 11:43 AM
    Thanks for the prompt reply.
    Yes I told customer but he is asking for he will press the backup and the back will save in Remote PC
  • neel
    92
    • November 25, 2021 at 6:00 PM
    My RW is 6.12
    I know the coding for system parameter.
    But customer want it through FTP to a remote PC.
    Can i try on my laptop first because i downloaded Filezilla client in my laptop.
    Can anyone help.
  • hermann
    404
    2,595
    • November 26, 2021 at 6:05 AM
    Quote from neel
    .. In robot we "FTP/NFS client option" and "PC Interface option" too...
    At least you need a ftp server on PC side. No communication from client to client possible.
  • neel
    92
    • November 26, 2021 at 6:10 PM
    Any free ftp server can you suggest which I can download in my laptop and test
  • SomeTekk
    16
    201
    • November 29, 2021 at 12:39 PM
    From another board that was posted on:
    FileZilla Server is running on the device named
    ToolPC: with a static IP of 192.168.3.39.
    One HUGE tip, change the default welcome message to
    %v
    Also the most current FileZilla server 1.1XX software has not been made to work for ABB controls with RW 5.15. It is suggested to download and use
    or later, or be willing to try and figure out with little FileZilla configuration information available how to get 1.1X to work.
    Reworking of the SIO parameters will be needed for RW6.
    SIO:CFG_1.0:5:0::
    COM_PHY_CHANNEL:
    -Name "COM1" -Connector "COM1"
    -Name "LAN1" -Connector "LAN"
    -Name "SER1" -Connector "SERVICE"
    COM_TRP:
    -Name "TCPIP1" -Type "TCP/IP" -PhyChannel "LAN1"
    COM_APP:
    -Name "StoragePlace" -Type "FTP" -Trp "TCPIP1"\
    -ServerAddress "192.168.3.39" -LocalPath "ToolPC:" -Username "IRC5"\
    -Password "XyZ" -MaxFileSize 150
  • FTP
