Advertising
Finding DH parameters for a robot arm with 6 DOF
  • Hi,
    In order to find the DH Parameter of a robot arm with 6 DOF you should follow a set of rules:
    First DH Parameter:
    You have a rotation around the Z-axis and a translation along the Z-axis
    and
    You have rotation around th X-axis and a translation along the X-axis.
    You could handle the Z-axis first and then the X-axis (standard DH parameter)
    or
    you could handle the X-axis first and then the Z-axis (modified DH parameter, sometimes also called DHm (or Craig))
    This gives you two differnt DH transformation matrices (and less or more work afterwards)
    Now the rules
    Number 1
    Draw a kinematic model of your robot
    draw the model as wire frame in the XZ-plane (why: see above) and all axes in Zero position (just to make live easier)
    do not scale
    Number 2
    the rotation of the robot axis is the z-axis needed for the DH parameter (normally here you have to check for the direction of rotation)
    in most CAD/CAM systems X-axis is red, Y-Axis is green and Z-axis is blue (easy to remember XYZ RGB)
    will be cont ....
    regards
    MOM
