Is it possible to activate one DO when i reach the point?
  • I am going to try to explain it correctly...
    The robot goes to one PR:
    L PR[36:Cell ] R[100]mm/sec FINE
    The robot reach this point and the program ends.
    In that moment i should to receive one DigitalSignal from this robot saying:"I reach this point". But i don´t receive this signal in my PLC...
    Logically, there is not an DO[]=On, after this PR.
    The question is if exist another way to activate this signal...?
    Maybe in one Backgorund program?
    Thank you so much guys!
  • To indicate the robot being within a specific position range (which is not necessarily the same as arrived there as a result of program execution), any of the following may be used:
    - Reference position (in joint coordinates only).
    - Space function, in world coordinates.
    - BG Logic with actual position reading (cartesian coordinates may be accessed in software v9, joint coordinates in any version).
    - Interference check.
  • I agree. If this is a program completion signal use DO in program. If this is a position confirmation use RefPos or other method Sergei mentioned. Less chance error that way if the DO is accidentally changed.
  • Thank you so much !!!
    Problem solved!
    I didn't remember that , however Ref Posn send me a signal when the robot reach this point!
  • Just curious What is the problem putting the DO after the PR ?
    I can't modified this program...
    Plus, the program should run like they send me...
    So, now i know how the robot send me this signal, with the ref posn
