Deviation from linear trajectory
  • Vlad222
  • July 27, 2020 at 2:30 PM
  • Vlad222
    161
    Hi all,
    I have troubles with linear trajectory while welding. Sometimes robot has big deviation from program path. There're 2 lines at picture:
    - program (ideal) traj - white line + white points.
    - real traj - red line.
    Deviation at picture is huge (about 4 mm). Velocity is very small ~6 mm/sec. Tool is right. It isn't near to singularity.
    Robot has reorientation but not large (joint rotation not critical). Path is good without reorientation. But I need this reorientation.
    I add to ARM Control right load data for S-head and U-arm. Tool load data also is correct. Smoothing is very small (~0.1 mm).
    How can I improve path accuracy? May be by changing some internal parameters? May be YASKAWA has a flag - reducing velocity for saving accuracy? Robot is MA1440 (DX200). It is new (1 year old).
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • July 27, 2020 at 3:08 PM
    Are you certain that the tool is very good? Check to see that the points do not have a different tool.
  • Vlad222
    161
    • July 27, 2020 at 3:15 PM
    Yes, tool is right. Deviation is because of robot dynamics
  • vmec
    7
    41
    • August 3, 2020 at 1:01 AM
    Can you program it manually? From defined P variable to another defined P variable with a MOVL. Test whether it is the controller or the program.
    You have many points for that straight line so maybe it's drawing a spline.
  • 95devils
    235
    8
    1,951
    • August 3, 2020 at 2:50 PM
    Check the robot calibration. Smaller robots with harmonic drives on the minor axes are susceptible to drive damage.
    Also, I don't know if your software is new enough, check in the INFORM LIST under OTHER for an instruction HTRAJON and HTRAJOF.
  • path accuracy
  • linear motion
