Hi guys,
need some advice, not sure what i'm doing wrong . i got this S10 Fanuc , i'm using kfloppy to install the software.
i press user #1 and user #2 then power on the robot. it get to the Bmo (or whatever it is called i called it the BIOS, i'm tired sorry).
I clean the CMOS and after do INIT.
Then i load the CORE + APP + Library . After that the teach pendant stays on loading from Library1.
So i unplug the cable of the teach pendant and replug it back. get the loading screen that everything is "OK"
so power the off the robot and power it back again. and i get insert core4 disk ... if i press enter it goes to loading via kfloppy again i restart the process over again like in a loop
it seem like i have the issue has this guy: KFLOPPY Problem with R-J Controller
Quote: "Thanks for the feedback everyone, I figured it out. I wasn't starting the R-J Controller in control mode and instead just starting it up after an init start. Once I held down USER PB#1 and PB#2 and started the controller that way, it would go though the entire install."
i guess what he meant by control mode it is my BIOS mode (BMO ? i'm doing it from memory) but he doesn't explain his install process.
