Configure EthernetIP protocol
  • zaidb
  • July 23, 2020 at 5:29 PM
  • zaidb
    10
    I have a Kuka KR 60-3 and a welding machine (Citowave III) that can be connected through EtherNetIP protocol.
    I've been trying to connect the two devices together but so far, no success.
    Here are the details:
    KSS 8.5.7 HF1
    Robot: 192.168.133.9
    Welding machine: 192.168.133.50
    I've also added a generic device where I'm setting the EDS and IP address of the welding machine as well as IO mapping
    My questions:
    1. Is EDS necessary to connect the two devices?
    2. Is I/O mapping necessary to start the EtherNetIP protocol?
    3. Is it possible to connect the welding machine to the port KONI? Or it can only be connected through KLI?
    4. What am I doing wrong?
    Thanks.
    Images
      • 125.65 kB
      • 1,919 × 956
      • 39
    Edited once, last by zaidb (July 23, 2020 at 5:42 PM).
  • zaidb July 23, 2020 at 5:33 PM
    Changed the title of the thread from “EthernetIP protocol” to “Configure EthernetIP protocol”.
  • panic mode
    1,267
    13,037
    • July 23, 2020 at 6:05 PM
    1. absolutely yes.... but you may be also use generic one too
    2. absolutely yes... On KRC end, EIP will not even try to run unless there is some data to move
    3. only through KLI because that is the port uses by EIP. KONI is for VisionTech, not EIP
    4. you did not state what EDS you use and how it is setup, or what I/O mapping you use
  • massula
    200
    8
    1,421
    • July 23, 2020 at 6:14 PM
    Quote from zaidb
    1) Yes, it is. The best option is load the EDS provided by the machine manufacurer on WorkVisual
    2) Technically speaking, the bus can "work" without the mapping, but this would be like post a letter without the sender and receiver addresses. Signals won't arrive where they should be.
    3) As far I know, isn't. KONI is used for specific applications, like vision systems.
    4) Is difficult to bet.
    But you are sure the welding machine is properly configured with the 192.168.133.50 ip address? You can ping the machine, or see it with other tool?
    And I would try to use the specific EDS provided by the vendor as well.
Similar Threads
  • Communication without modules
    • Stest69
    • May 14, 2020 at 2:35 PM
    • Fanuc Robot Forum
  • KRL to KAREL match cases
    • Latoff
    • February 13, 2020 at 9:52 PM
    • Fanuc Robot Forum
  • Allen Bradley to FANUC R30iA on Ethernet IP
    • starlord_94
    • November 11, 2019 at 4:38 AM
    • Fanuc Robot Forum
  • PickMaster3 in connection with external sensor problem
    • blizz1993
    • July 17, 2019 at 2:21 PM
    • ABB Robot Forum
  • How to change force setting on collaborative robot (CR-7iA)
    • tomexx
    • May 13, 2019 at 2:31 PM
    • Fanuc Robot Forum
  • KUKA KRC4 and Beckhoff PLC Communication
    • mamatha
    • October 10, 2016 at 2:11 PM
    • KUKA Robot Forum
  • FANUC DCS CPC thru ethernet
    • Davidmacias_87
    • June 21, 2018 at 1:48 AM
    • Fanuc Robot Forum
  • Fault reset by push button
    • NovaFlatline
    • May 27, 2018 at 5:54 PM
    • Fanuc Robot Forum
  • KUKA KRC4 to PLC communication using EthernetIP to Profinet Anybus X-Gateway
    • rich_goodchild
    • January 31, 2017 at 9:19 PM
    • KUKA Robot Forum
  • weld
  • ethernet/ip
