Code Review for KRC2 2005ed and Other Questions
  • Nation
  • July 17, 2020 at 10:59 PM
    Nation
    Typical Robot Error
    537
    1,917
    Gents,
    I'm outside of my comfort zone, and working on a small job programming a KRC2 2005 edition with a KR 30 arm. It is running V5.5.10. This robot is essentially a demo robot that will live in a conference room, and mirror the user's right hand motions which are streamed in via RS232. Hand coordinates are produced by a C# application interfacing with a Azure Kinect depth camera. The robot has no tool on it.
    I've got it up and running and figured I would ask the experts here for their opinion on ball of code I've managed to produce in the last few days. The core of it built around @SkyeFire's code in this thread. Just to get the warm and fuzzies that I am not doing anything drastically wrong.
    Here is the .scr module:
    &ACCESS RVP
    &REL 64
    &PARAM EDITMASK = *
    DEF serial( )
    DECL BOOL Pass
    DECL INT I
    DECL POS Shift
    MOVEHOME:
    ;FOLD PTP P7 Vel=25 % PDAT7 Tool[0] Base[0];%{PE}%R 5.5.31,%MKUKATPBASIS,%CMOVE,%VPTP,%P 1:PTP, 2:P7, 3:, 5:25, 7:PDAT7
    $BWDSTART=FALSE
    PDAT_ACT=PPDAT7
    FDAT_ACT=FP7
    BAS(#PTP_PARAMS,25)
    PTP XP7
    ;ENDFOLD
    ; Set base as the PTP point above.
    $BASE = $POS_ACT
    $TOOL = $NULLFRAME
    ; Set Velocites
    $VEL.CP=1
    $VEL.ORI1=400
    $VEL.ORI2=400
    $ACC.CP=10
    $ACC.ORI1=100
    $ACC.ORI2=100
    REREAD:
    ; Init receiving string
    Pass = strclear(Result[])
    Offset=0
    ;Get a position from the host computer.
    COPEN (:SER_3, Handle) ; open serial port COM3
    Mode = #ABS ; CREAD waits for data or timeout
    WAIT FOR ($DATA_SER3 <> 0) ; wait for data in COM3 buffer
    ; read serial buffer into RX string
    CREAD (Handle, RX_State, Mode, Timeout, Offset, "%s", Result[])
    CCLOSE (Handle, CH_State) ; close serial channel
    ;Occasionally a malformed string comes across. Need to investigate.
    IF STRLEN(Result[])<20 THEN
    GOTO REREAD
    ENDIF
    ;Replace Commas with spaces so SREAD will work.
    FOR I = 1 TO STRLEN(Result[])
    IF (Result[I]==",") THEN
    Result[I]=" "
    ENDIF
    ENDFOR
    Offset = 0 ; Start SREAD from first string character
    SREAD (Result[], CH_State, Offset, "%7f %7f %7f", X_Result, Y_Result, Z_Result) ; extract X Y and Z values from string
    ;Cap the values passed in. Probably a better way to do this.
    IF (X_Result>500) THEN
    X_Result=500
    ENDIF
    IF (X_Result<-500) THEN
    X_Result=-500
    ENDIF
    IF (Y_Result>500) THEN
    Y_Result=500
    ENDIF
    IF (Y_Result<-500) THEN
    Y_Result=-500
    ENDIF
    IF (Z_Result>500) THEN
    Z_Result=500
    ENDIF
    IF (Z_Result<-500) THEN
    Z_Result=-500
    ENDIF
    ;Apply the camera position. Kinda hacky.
    Shift = $POS_ACT
    Shift.x = Y_result
    Shift.y = -X_result
    Shift.z = Z_result
    Shift.a = 0
    Shift.b = 0
    Shift.c = 0
    ;Move to commanded position.
    PTP Shift
    GOTO REREAD
    END
    and the .dat file:
    &ACCESS RVP
    &REL 21
    &PARAM EDITMASK = *
    DEFDAT SERIAL PUBLIC
    DECL INT Handle=3
    DECL INT offset=0
    DECL REAL Timeout=5.0
    DECL STATE_T TX_State={RET1 #CMD_OK,MSG_NO 0,HITS 1,LENGTH 0}
    DECL STATE_T RX_State={RET1 #DATA_BLK,MSG_NO 0,HITS 1,LENGTH 21}
    DECL STATE_T ch_State={RET1 #DATA_END,MSG_NO 0,HITS 3,LENGTH 0}
    DECL MODUS_T Mode=#ABS
    DECL CHAR Result[100]
    Result[]=" "
    DECL REAL X_Result=92.0999985
    DECL REAL Y_Result=401.899994
    DECL REAL Z_Result=790.700012
    DECL BASIS_SUGG_T LAST_BASIS={POINT1[] "P7 ",POINT2[] "P7 ",CP_PARAMS[] "CPDAT0 ",PTP_PARAMS[] "PDAT7 ",CONT[] " ",CP_VEL[] "2.0 ",PTP_VEL[] "25 ",SYNC_PARAMS[] "SYNCDAT ",SPL_NAME[] "S0 "}
    DECL E6POS XP1={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP1={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT1={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    DECL E6POS XP2={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP2={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT2={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    DECL E6POS XP3={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP3={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT3={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    DECL E6POS XP4={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP4={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT4={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    DECL E6POS XP5={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP5={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT5={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    DECL INT LAST_XP_POINT=7
    DECL E6POS XP6={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP6={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT6={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    DECL E6POS XP7={X 751.742126,Y 486.357605,Z 1312.63306,A -80.4673462,B 87.5570297,C -113.480103,S 6,T 19,E1 0.0,E2 0.0,E3 0.0,E4 0.0,E5 0.0,E6 0.0}
    DECL FDAT FP7={TOOL_NO 0,BASE_NO 0,IPO_FRAME #BASE,POINT2[] " ",TQ_STATE FALSE}
    DECL PDAT PPDAT7={VEL 100.0,ACC 100.0,APO_DIST 100.0}
    ENDDAT
    One thing I am running into (in teach high speed) is that when the robot reaches the shift point, it engages the brakes, then releases them when it jumps back up and reads in another position. Is there a way to prevent that behavior? AKA keep the brakes released.
    Also, if anyone has any suggestions on how to speed up the code so the robot is more responsive I am all ears. I've had to slow the streaming down on the computer side to about 1Hz. Otherwise I get buffer overflow errors. Also if anyone knows how to clear the buffer, that would be helpful.
    hermann
    406
    2,609
    • July 18, 2020 at 9:22 AM
    Don't open/close serial port in every loop, just open once at beginning.
    Change the format of the string that you don't have to convert strings to commas.
    The behavior of the brakes seems curious, normally they should be released at least for about 10 seconds after one movement.
  • Mentat
    61
    5
    243
    • July 20, 2020 at 11:03 AM
    $BASE = $POS_ACT
    Is a bold and daring line- I would change it to some constant, maybe the same homepos.
    Don't use GOTO, KRL provides functionality to write functions, procedures, loops, if and case statements- use those instead.
    Limiting the values like this leaves them overly dependent on the homepos; also instead of a cube I would limit to a sphere- less jarring, at least for me.
  • MOM
    175
    7
    1,424
    • July 22, 2020 at 6:54 PM
    I also have a Suggestion:
    Do not send your data as string, send them in binary format and receive them like this:
    CREAD(HANDLE,SR_T,MR_T,TIMEOUT,OFFSET_CR,"%r%.6r",IPOSNO,POSV[],PARMS[])
    This will also speed up the communication and will not cause any problem by converting to float or double (you have to check first), afterwards it will be working pervectly.
    With this I never had problems as you described.
    Regards
    MOM
    Nation
    Typical Robot Error
    537
    1,917
    • November 3, 2020 at 10:49 PM
    Finally back on this job, as I've has some free time appear in my schedule.
    Quote from Nation
    Found out that the previous owner of this robot had set $BRK_DEL_PRO to 200. That was causing the odd brake behavior.
    Currently working on getting it up and running in auto.
  • Emben22
    43
    • November 4, 2020 at 9:41 AM
    Had the same issue of buffer overflow when we were working on robotic Air Hockey .
    We used rsi and a krc4 agilus.
    we did 2 things to fix it.
    1. we clear the buffer after receiving a data. (which i dont know how to do it on krc2)
    2. from C# code we are limiting the sent data. its either the the first point or the last point detected from the camera.(robot is runs at full speed).
    Nation
    Typical Robot Error
    537
    1,917
    • November 6, 2020 at 9:07 PM
    While it is pretty easy to get the robot up and running in AUT, I'd like to have it so the end user only has to press a single start button. I was hoping to do this by monitoring the fence circuit and then resetting the messages and starting the program once it is clear. In Fanuc world this is fairly easy, but the more I dig into this, it looks like at the minimum I would have to wire some outputs to inputs.
    Is there a way to map the EXT AUT signals to a virtual signal?
    panic mode
    1,278
    13,079
    • November 6, 2020 at 9:44 PM
    i wish this was possible in IOSYS.INI like with [IOLINKING]
    would like that on KRC4 too...
