I am working now on a simple application consist of [ FANUC ROBOT M-10iA ] will be connected to [ PLC AB ] only by using
_ 5 DO coming from PLC then will be 5 DI in Fanuc side ]
_ 1 or 2 DI to PLC which they will be 2 DO from Fanuc side .
so first pont I will talk about PLC DO:
- DO to start Robot
- 3 DOs to select three Different programs.
second point PLC DI :
- ROBOT is busy.
my question is:
A) regarding to PLC DOs / Robot DIs:
1- How can I configure Robot DIs [ which rack, slot , Start] values can insert.
2- according to my understanding Robot DIs should be mapped with UOPs signal to activate Start , to select programs.
B) regarding to PLC DIs / Robot DOs:
- same situation .
I know it is very basic question but also I need to know from where can i get this information regarding to the Robot cabinet Hardware types , Cabinet wiring diagram .
Thanks In Advance,
Moelsayed
