Okay, so what are the master counts and what do I use them for?
Mastering at a Non-zero position - R30iA Controller Fanuc
alive15 -
July 1, 2020 at 4:12 PM -
They are the mastering. They relate the encoder count to the mastered position.
When you purchase a new robot you have to enter them in.
If the relationship changes then they are no longer valid. But if not they can be used to remaster.
I see, so this master count value always remains the same throughout the life of the robot, unless power goes off and batteries are dead, correct? Then once these are replaced, these values will automatically change? So I have to get the original master count data and put this back into the robot, correct?
Or is the master count data always changing whenever the robot moves around?
The counts stay the same unless you change them either manually or by mastering. They don't automatically change.
If the encoder relationship changes then you will remaster and end up with new values.
Before the addition of single axis quick master, the counts could be used to revert axis' unintentionally quick mastered back to their proper values. Any more, I don't find myself ever using them.
Just to follow up with everyone, the issue with the above fault was a bad RP1 cable (going from back of robot into the controller). We also replaced the ground wire as well. Then, the problem went away.
Thanks for all the information, especially to HawkME !
