Hello
I'm new in FANUC programming.
I'm trying to do the simple user form from FANUC KAREL manual. As it says, I maked the .FTX file and then converted it with kcdict utility, which was installed with roboguide. As a result, I got two files: .TX and .VR. After that I tried to load these files in robot. The .VR file loads normally, but I cant load .tx file. TP says that "File is not loadable". I tried to copy this file from UT1: to MD:, but it also does not work - i got an error "no dict found for language".
There is no doubt, that I doing something wrong. Could you help me please with it?
I attach the .TXT file of form to this message.
I know, that I need the KAREL program to call this form. I made one, but it does not work with an error INTP-311 Uninitialized data
