Advertising
offsetting points
  • Looking to create a programme for a mig robot to dip the nozzle into anti spatter paste, I am thinking of putting a small square container inside the weld cell and after the nozzle clean I want the robot to dip the nozzle into anti spatter paste but each time it goes in I want it to dip into a different part of the container so need a simple programme that can offset the points and then repeat.
    Regards
  • An example of a robot program I can create that will do what I want. little example
    << COMMAND(S) >>
    <-> Begin of Program
    TOOL = 1:TOOL01
    (+) MOVEP P023 90.00m/min
    (+) MOVEP P025 90.00m/min
    [ ] :START
    INC GB#(2:REAMER COUNTER)
    IF GB#(2:REAMER COUNTER) < 17 THEN JUMP REAMER ELSE JUMP RESET COUNT
    [ ] :REAMER
    IF GB#(2:REAMER COUNTER) = 1 THEN JUMP LABEL0001 ELSE NOP
    [ ] :LABEL0001
    (+) MOVEL P005 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 2 THEN JUMP LABEL0002 ELSE NO
  • There's quite a bit questionable about your example (maybe some of it's missing?), but your true goal should be to get an anti-spatter sprayer. Even if you accomplish what you want with the dip, the torch will eventually dip into filthy gel I would think. Most if not all nozzle cleaners come with a nozzle sprayer. If it doesn't work I would fix or replace it. If there isn't one at all I would install one.
  • It is only part of the program ,it goes on so the torch can dip sixteen times. We already have a nozzle clean but the anti spatter spray gets forced up into the nozzle and contaminates everything. The dip would only be used after 6 torch cleans or more which is then 6 times torch clean times 16 dips which would take us until end of two complete shifts and operator would then level the dip tray with new paste which would be a 5 minute job. We find the paste is a lot cleaner.
    -> Begin of Program
    TOOL = 1:TOOL01
    [ ] :START
    [ ] :REAMER
    [ ] :LABEL0001
    JUMP END
    IF GB#(2:REAMER COUNTER) = 2 THEN JUMP LABEL0002 ELSE NOP
    [ ] :LABEL0002
    (+) MOVEL P006 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 3 THEN JUMP REAMER ELSE NOP
    [ ] :LABEL0003
    (+) MOVEL P007 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 4 THEN JUMP LABEL0004 ELSE NOP
    [ ] :LABEL0004
    (+) MOVEL P008 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 5 THEN JUMP LABEL0005 ELSE NOP
    [ ] :LABEL0005
    (+) MOVEL P009 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 6 THEN JUMP LABEL0006 ELSE NOP
    [ ] :LABEL0006
    (+) MOVEL P010 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 7 THEN JUMP LABEL0007 ELSE NOP
    [ ] :LABEL0007
    (+) MOVEL P011 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 8 THEN JUMP LABEL0008 ELSE NOP
    [ ] :LABEL0008
    (+) MOVEL P012 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 9 THEN JUMP LABEL0009 ELSE NOP
    [ ] :LABEL0009
    (+) MOVEL P013 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 10 THEN JUMP LABEL0010 ELSE NOP
    [ ] :LABEL0010
    (+) MOVEL P014 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 11 THEN JUMP LABEL0011 ELSE NOP
    [ ] :LABEL0011
    (+) MOVEL P015 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 12 THEN JUMP LABEL0012 ELSE NOP
    [ ] :LABEL0012
    (+) MOVEL P016 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 13 THEN JUMP LABEL0013 ELSE NOP
    [ ] :LABEL0013
    (+) MOVEL P017 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 14 THEN JUMP LABEL0014 ELSE NOP
    [ ] :LABEL0014
    (+) MOVEL P018 90.00m/min
    JUMP END
    IF GB#(2:REAMER COUNTER) = 15 THEN JUMP LABEL0015 ELSE NOP
    [ ] :LABEL0015
    (+) MOVEL P019 90.00m/min
