Is there any way to unset a variable?
  • robotecnik
  • June 22, 2020 at 8:32 PM
  • robotecnik
    19
    568
    KRC2, KSS5.x.
    I've prepared a palletizing program that has been working for days now...
    All day they have been making parts and "suddenly" the robot started rotating the 6th axis while going to pick the part.
    I'm sure they have made a modification in the program... But tomorrow I will confirm it.
    There are 3 points to get a box:
    1. Approximation (pPre1).
    2. Vacuum cups almost touching the box (to allow them to adjust the cups if needed) (pPre2).
    3. Pick position (p).
    In the first point I've set the T value, the other 2 ones have not...
    I assign the coordinates this way:
    rX = iXBox/2.0
    rY = iYBox/2.0
    rZ = iZBox*1.0
    rA = 90.0
    pPre1.X = rX
    pPre1.Y = rY
    pPre1.Z = rZ + rZOffs
    pPre1.A = rA
    pPre1.T = 'B 100010'
    pPre2.X = rX
    pPre2.Y = rY
    pPre2.Z = rZ + rZOffs
    pPre2.A = rA
    p.X = rX
    p.Y = rY
    p.Z = rZ
    p.A = rA
    The robot starts rotating going from pPre1 to pPre2... which should not as the point has the same coords except from Z and T (which pPre1 has initialized and pPre2 has not).
    As you can see I've not updated the T parameter of "pPre2" nor "p"...
    Of course, if they have touched up the position the S and T will have appeared and therefore the robot could want to go to the destination position...
    I can solve it by accessing the $Config.dat file and remove it manually, but... could I do it programatically?
    If that would be possible I would be able to program a small routine to leave the points as I want before starting the program.
    As always thank you in advance.
    http://www.robotecnik.com | Robots, CNC and PLC programming.
  • panic mode
    1,268
    13,040
    • June 23, 2020 at 12:58 AM
    >> " Is there any way to unset variable?"
    not that i know of... but you can create new runtime variable and not initialize parts you don't care about which i believe is what you are trying to do.
    ;P1 is fully initialized for example P1=$POS_ACT
    PTP P1 ; move to P1 (using all elements of the P1 which is usually E6POS), including Turn value
    P1 = WithoutTurn(P1) ; update P1 but ignore (unsets) Turn for example
    PTP P1 ; now we have no turn value programmed....
    DEFFCT E6POS WithoutTurn(P:in)
    DECL E6POS P, temp
    temp.X = P.X ; selectively copy elements of P. elements not copied will be uninitialized
    temp.Y = P.Y
    temp.Z = P.Z
    temp.A = P.A
    temp.B = P.B
    temp.C = P.C
    temp.S = P.S
    ; temp.T is not initialized
    temp.E1 = P.E1
    temp.E2 = P.E2
    temp.E3 = P.E3
    temp.E4 = P.E4
    temp.E5 = P.E5
    temp.E6 = P.E6
    RETURN temp
    ENDFCT
  • robotecnik
    19
    568
    • June 23, 2020 at 2:26 PM
    Great!
    Thank you panic mode !
    By the way... Nothing was wrong with the program nor the robot... I've went to the customer place because an operator had added a point into the program...
