Kuka ArcTechDigital Welding
  • phi
  • June 22, 2020 at 7:06 PM
  • phi
    I have a question regarding the Kuka Arc Tech Package:
    In our company we have the following situation:
    If the ignition of the arc fails the robot stops and if I restart the robot tries again to light the arc.
    If I restart 3 times the robot continues without welding the current seam. The Error message is "Continue without welding"
    We want to change this behaviour (to continue without welding).
    Therefor I searched in the manual.
    According to the manual the parameter is "RESTART_OPT" which was 3.
    First I tried:
    I changed the parameter to 1:
    "After welding has been interrupted, the robot repositions
    the torch to the point of interruption. Welding is subse-
    quently restarted."
    Unfortunately there was no change in the robots behaviour when I changed this parameter.
    Then I tried:
    Then I changed the parameter to RESTART_OPT=2:
    "The same function as with “RESTART_OPT=1”, with the
    restriction that the number of permissible welding inter-
    ruptions is limited to a maximum value.
    This maximum value is defined in the variable
    “MAX_REA20”. If this value is exceeded, the seam is
    completed without welding and a corresponding
    message is generated."
    Therefor I changed the parameter MAX_REA20 to the value 99
    but again: after 3 tries the robot continues without welding
    I kindly ask for your support since I dint find any other solution in the manual
    many thanks in advance :thumbs_up:
Similar Threads
  • Kuka KRC2 configuration with TransPulse Synergic 4000
    • Francesco Pantoli
    • June 28, 2019 at 6:51 PM
    • KUKA Robot Forum
