Hello guys!
I'm just starting my adventure with robot programming as a junior engineer. In the past I used to be in contact with ABB and OTC robots, and now my job is to program the Kawasaki FS20N polishing process for the new company. I have two problems and I kindly ask for help.
One of the employees accidentally just typed in the "exe" command (without program name after "exe") and approved it. The robot moved forward and the J5 axis bent and damaged the pneumatic spigot. We quickly stopped the robot in an emergency and replaced the spigot with a new one. After restarting the robot, a "W1013 encoder battery low voltage [Servo(0)]" error appears on the computer screen and a red error light on the control cabinet keeps lighting up. After deletion it, I tried to put the robot in the starting position manually, but the robot is behaving strangely. In a kind of "base point" control the axes do not work properly. The robot moves in different axes and directions than I control. What battery should I buy and where is it located to replace it? Is it enough to change the battery and it should be working again?
And my second probelm:
I wrote the program about a month ago and it worked without problems. The boss asked me to back up the program for fear of losing data. So I downloaded the programs from the robot's memory to a CF card (the first time I had one in my hands ) and took it out. Out of curiosity I turned on the program without the card and it turned out that it worked, so I left it like this, without the card inside. It turned out that after one of the sub-programmes was done, the polishing discs stop working, even though the robot is still making the right moves. What should I do? Is it enough to upload the programs back into the robot's memory? I can insert a screenshot of the program here.
I kindly ask for any help!
