Variable to keep the error message
  • Fabian Munoz
  • June 19, 2020 at 5:28 PM
  • Fabian Munoz
    133
    Articles
    1,517
    Hi
    Which is the variable that holds , for example "SRVO-003 Deadman switch released "
    I looked in may places on the variables and I couldn't find it
    Regards
    Retired but still helping
  • scotty
    43
    5
    497
    • June 19, 2020 at 6:07 PM
    • Best Answer
    You need to enable : $ALM_IF.$ENABLE
    Then use for last alarm : $ALM_IF.$LAST_ALM
    for last user alarm: $ALM_IF.$LAST_UALM
  • Fabian Munoz
    133
    Articles
    1,517
    • June 19, 2020 at 6:12 PM
    I didn't have the enable TRUE
  • Fabian Munoz
    133
    Articles
    1,517
    • April 20, 2021 at 12:59 PM
    Almost a year later, I'm bringing more questions about $ALM_IF
    I guess there are a couple of ways to read the last alarm (explicit messaging or Karel).
    Any idea how to read the other ones.
    I've been reading about it in the last couple of days (without actually programming) and I can't find anything that can take me directly to $ALM_IF.$CURR_STAT for example
    Any ideas ?
    BTW, the reason that I'm is because we are buying lets say 4 robot for a system with only one pendant. 3 pendants are basically the price of one robot. That makes my life hell and I want to send the PLC-HMI all the info that I can
  • Nation
    Typical Robot Error
    542
    1,924
    • April 20, 2021 at 2:47 PM
    What PLC/HMI and comm package are you using?
  • Fabian Munoz
    133
    Articles
    1,517
    • April 20, 2021 at 3:27 PM
    Allen Bradley with EthernetIP
    We've done a lot of things with explicit messaging and Karel but we still need to do more. Not having pendants on every robot is painful
  • Nation
    Typical Robot Error
    542
    1,924
    • April 20, 2021 at 6:05 PM
    I'm pulling the alarm out of a system right now.
    Setup an explicit message with the following parameters, and it will be the current error.
    If the message faults, its because there is no fault active.
    The tag it is writing to is a normal string tag.
  • Fabian Munoz
    133
    Articles
    1,517
    • April 20, 2021 at 7:51 PM
    Thanks I've got that and I was very excited but how do you get the rest of the $ALM_IF ?
    I'm talking to Fanuc also and seems to me that there is no way you can read a system variable result and put it on a SR[ ]
  • Nation
    Typical Robot Error
    542
    1,924
    • April 20, 2021 at 8:39 PM
    Doesn't look like there is a way to pull out a system var with Ethernet/IP explicit messaging.
    However, you could write a Karel routine that pulls out the $ALM_IF structure, and dumps them into some string registers. Those can be read via explicit messaging.
    EDIT: there is also Explicit Data Access, which allows reads of system vars, but it is also an option.
  • Fabian Munoz
    133
    Articles
    1,517
    • April 20, 2021 at 9:32 PM
    1) NO pull out system var
    2) THis is the only Karel command that resembles what I want
    GET_VAR Built-In Procedure
    Purpose: Allows a KAREL program to retrieve the value of a specified variable
    Syntax : GET_VAR(entry, prog_name, var_name, value, status)
    Input/Output Parameters:
    [in,out] entry :INTEGER
    [in] prog_name :STRING
    [in] var_name :STRING
    [out] value :Any valid KAREL data type except PATH
    [out] status :INTEGER
    and I have this
    I'm going to try to read it
    3) Fanuc mentioned the EDA but I don't have that option, even that I have EIP
    Thanks Nation
  • scotty
    43
    5
    497
    • April 20, 2021 at 10:02 PM
    • #11
    I've not used explicit msg a lot. But I use KAREL to read sys vars and based on matches/conditions set a bit or send an error code over GO[*] and another one GO[*] for error type SRVO/MTN/etc. As an option...
  • Fabian Munoz
    133
    Articles
    1,517
    • April 20, 2021 at 10:44 PM
    • #12
    Hi I'm home now, but I was having a hard time implementing the GET_VAR to read the CURR_STAT. I'm having a compilation error. The examples in the Karel manual are not helping me much
    I'll try again tomorrow morning, so, scotty, if you don't mind check the thread and give me a hand
  • scotty
    43
    5
    497
    • April 21, 2021 at 12:01 AM
    • #13
    I know it's silly, but you can try this one.
    Files
    get_currStat.txt 730 Byte – 167 Downloads
  • 1Cliff
    • April 21, 2021 at 8:50 AM
    • #14
    Other idea (If using Karel):
    Just read 'ERRACT.LS' from memory.
    It contains all the current errors...
  • Fabian Munoz
    133
    Articles
    1,517
    • April 21, 2021 at 4:06 PM
    • #15
    Thanks to scotty I was able to achieve my goals
    The attachment shows what I did for me but also gives a good reference how to read system variables and load them on Rs and SRs
    Karel sample.docx
  • Clark111
    • April 30, 2021 at 11:12 PM
    • #16
    Hey,Fabian:
    about the sample,i have a question,I tried it on robotguide, but I couldn't get this parameter well. In addition, I can't find these three parameters in the variables: $ALM_IF.$CURR_PROG, $ALM_IF.$CURR_STAT, $ALM_IF.$CURR_LINE.
  • Fabian Munoz
    133
    Articles
    1,517
    • May 1, 2021 at 8:41 PM
    • #17
    Hi
    Clark111 Welcome to the robot forum
    Can you post a picture of the ALM_IF parameters, What do you see when you go to details ?
    I will check more on Monday. I'm home now
  • Clark111
    • May 5, 2021 at 4:28 AM
    • #18
    Hi,sir.Thanks for the reply. Your program is well written, and I can successfully load it. But I did not find in my robot parameters: 1, $ALM_IF.$CURR_PROG; 2, $ALM_IF.$CURR_STAT; 3. $ALM_IF.$CURR_LINE. It should be that the version of my robot and the application are inconsistent with the version you are using.
  • SergeyG
    7
    • July 27, 2021 at 9:53 AM
    • #19
    Quote from Fabian Munoz
    Hi,Fabian.
    what options you install, to not use the pendant?
  • Fabian Munoz
    133
    Articles
    1,517
    • July 27, 2021 at 12:33 PM
    • #20
    hi
    The robot we but mostly (Scara) use the compact controller. The no pendant option is part on the standard package.
    Images
      • 143.99 kB
      • 675 × 1,200
      • 35
