Can't connect to Electronic Mastering Device (EMD)
  • Mentat
  • June 19, 2020 at 1:18 PM
  • Mentat
    61
    5
    243
    Setting up a robot- KR120 R3100-2 with KSS 8.6.5. Set up went well until I got to mastering- after jogging robot to premastering position and connecting EMD to X32, the pendant does not detect the EMD. I have checked the EMD with other robots- works well; the X32 connector on the robot looks clean.
    I suppose contacting KUKA is the next step, but maybe any of you ran into something like this before?
    panic mode
    1,278
    13,079
    • June 19, 2020 at 2:52 PM
    EMD interface is a short cable from RDC to box. if someone was messing with the RDC box (adding external axis etc.) chances are they did not plug it in correctly or in correct place. it could also be that one of the contacts is not ok (bent, pushed out, etc.)
  • Mentat
    61
    5
    243
    • June 23, 2020 at 9:31 AM
    The wires of contact to connect to the EMD were pulled in.
    Solved.
  • Dbonds28
    16
    • September 28, 2023 at 9:04 PM
    hey im having the same problems
  • Mentat
    61
    5
    243
    • September 28, 2023 at 9:24 PM
    Quote from Dbonds28
    Open the box with the X32 connection and see if maybe the wires are pulled in? Or did you do that already and it was ok?
  • Dbonds28
    16
    • September 29, 2023 at 9:35 AM
    Yes its a brand spanking new robot, and SEMD it says (Image posted below)
    Images
      • 1.65 MB
      • 900 × 1,200
      • 28
Similar Threads
  • About to receive my first KUKA robot... setup preparations.
    • Koppel
    • February 13, 2019 at 9:16 PM
    • KUKA Robot Forum
  • KRC2 pendant extremely dim
    • Wall-E
    • June 9, 2018 at 10:01 AM
    • KUKA Robot Forum
  • Things to do before buying a used KRC4 & KR 6 R700 robot
    • teamamerica
    • September 22, 2016 at 5:03 AM
    • KUKA Robot Forum
  • mastering
  • EMD
