Motor from KRC2 to KRC4
  • manhunt
  • June 16, 2020 at 9:29 AM
  • manhunt
    36
    Hi! Here is KR120 R2700 extra HA, KSS 8.2 KRC4
    I want to connect a linear unit for this KRC4.
    We found a linear unit from Zollern which contains a motor (1FK6100-8AF91-1ZZ9-Z S49). This motor had worked with Kuka KRC2 controller.
    I know the differences between KRC4 model (which use KSP/KPP modul and RDC plate) and KRC2 model (which use KSD modul and RDV plate)
    I mean it is possible to connect this motor to KRC4, but I haven't any data about this motor to choose KSP and configure it in the Workvisual
    motor-label
    Edited once, last by manhunt (June 16, 2020 at 11:56 AM).
    panic mode
    1,262
    13,027
    • June 16, 2020 at 1:40 PM
    Motor can be connected to KRC4. The only issue is if you can find it it the WoV catalog. If not there new catalog entry is needed. Usually this means contacting KUKA unless you get familiar with WoV catalog editor.
    Btw RDC and RDW is the same thing, just in different language.
    "C" = "Converter"
    "W" = "Wandler" (German word for converter)
    In the past German term was more used but with KRC4 there is a push to make things English
  • manhunt
    36
    • June 17, 2020 at 7:09 AM
    Hi, Panic mode! Thanks for your fast reply.
    I had a response from Kuka for this issue.
    This motor is not supported now, but I can use its follower 1FK7032, art: 00-136-925.
    I didn't know the differ btw RDC and RDW predominantly in Ger/Eng name. I thought it has a difference in principle
  • Mizio31
    24
    • May 8, 2025 at 8:23 PM
    • New
    hi Panic, im done with new kpp1 by insert the wagon driver(other tread). Now i’m in the same situation of Manhunt. But i belive that can i use 1fk6100 motor on krc4 kss 8.2.7. Can you help my a bit to setup a kl1500/2 with 1fk6100 motor? In catalogs i just found kl1500/3 in varius format
    panic mode
    1,262
    13,027
    • May 8, 2025 at 8:38 PM
    • New
    i lost track of this thread but info manhunt got about motor compatibility is wrong. 1FK6100 is a way larger motor (3.7kW) than 1FK7032 (0.5kW). when looking for substitutes one need to watch things like size, speed, number of poles, thermistor type, feedback type... (KUKA RDC only works with resolvers) etc.
    about setting up linear rail with different motor: what help do you need exactly?
    panic mode
    1,262
    13,027
    • May 8, 2025 at 8:52 PM
    • New
    here are some of key things from $machine.dat taken from robot that was on custom rail and running KSS8.2
  • Mizio31
    24
    • May 9, 2025 at 7:25 AM
    • New
    My motor its 1fk6100 3,7kw. Ok i’ll check this parameter on the robot were the track was before(krc2) and i’ll make the same
