Dear Forum friends,
I'm building an Line tracking demo with our study robot and an cognex camera.
I thought to start simple by following the application example in the insght explorer help file.
I did set up the Fanuc communication over ethernet ip , I get my Digital inputs on my Teach Pendant.
Also the Digital outputs are wording , if I send an trigger then the Cognex does trigger and sends results .
However the DI-DO and GI are responding the GI X position Y position and Angle stay 0
The GI for inspect ion does show a number.
I have checked the walk through from Cognex several times but I don’t see where I made a mistake.
Is there anyone who has tried to do this also?
Is there maybe an reason why the Cognex does work but does not send data ?
In the insght explorer i do see the data to send to Fanuc, but I can’t see what the Cognex does send out to the robot or is there a way?
Robot controller R30iA
Cognex is7802
Com: Ethernet ip
Insight job from Help file:
In-Sight Job Setup
- From the File menu, create a New Job.
- In the AcquireImage property sheet (double-click on cell A0), set the following parameters:
- Trigger = External
- Manual = Checked
- Select cell A2 and type ExtractBlobs and press Enter (at this point the ExtractBlobs property sheet will be displayed).
- Click OK (leaving all parameters at their default settings).
- Select cell A4 and, from the Palette's Snippets tab, insert the Communication > Robots > FANUC Communications Snippet into the spreadsheet.
- Define the coordinate cell references:
- X: Double-click C6, double-click C2,
- Y: Double-click D6, double-click D2
- Angle: Double-click E6, double-click E2
- Press the Manual Trigger icon a few times to confirm that data from the ExtractBlobs function is changing.
- Save the job.
- Put the vision system Online
