and please can you give m the bus param and thank you very very much
external module configuration ( profibus )
- terminator
First thing, if You have only one 4DO module then You have input bytes 0, output bytes 1.
For master You have to look in plc controller what is reserved (byes in/out) for robot communication and what adress is signed for robot. -
i have done it , it was a profibus cable problem and i fix it thank you very very very much for you bowth
Hi!
I hope you can help me also to configuring my system. A have an S420iF fanuc rj2 with profibus module and a simple i/o modul (wago 750-323). A try to set up the robot-i/o module but it doesn't work. I have the gsd file of the wago device, but i don't understand wich parameters have to set up in the robot menu. Can you help me?
Hi!
Hope you can help me. I have a FANUC robot RJ2 with Profibus module (WAGO ECO "ref750-343" with 16 inputs and 16 outputs). attempt to set the robot-i / o module, but does not work. I have the GSD file WAGO device, but I do not understand parameters have to be set in the menu robot. Can you help me?
Thank you very much.
