  4. Kawasaki Robot Forum
AS Language for Kawasaki robot controller
  • visi
  • May 29, 2020 at 4:32 PM
  • visi
    Heya, Kawasaki robot controller have different series (E, F,.. ).
    Is the AS language syntax different or similar for each series ?
    If they are different, could someone write the difference with the example provided below.
    I assume the following is the syntax for E series.
    .PROGRAM Sequence1()
    TOOL *NULL*
    BASE *NULL*
    ACCURACY CNT0 ALWAYS
    RIGHTY
    ABOVE
    DWRIST
    SPEED 100 ALWAYS
    JMOVE TRANS(0.000000, 1830.306919, -135.762774, -90.000000, 90.000000, 90.000000)
    SPEED 9000 MM/S ALWAYS
    LMOVE TRANS(0.000000, 1260.839079, -135.762774, -90.000000, 90.000000, 90.000000)
    .END
    Is the above syntax different for other controller series or same ?
    Thank you:smiling_face:
  • Alexandru
    49
    407
    • May 29, 2020 at 6:32 PM
    The as syntax should be the same, newer controllers have more options.
    Do you have the AS Language manual ??
    You can take it from here: AS programming
  • roboperson
    27
    • June 30, 2020 at 7:48 AM
    AS language (Advanced Superior) has stayed pretty much the same since even way back to the Unimates. Some things do change for example I've seen controllers require the entire word "edit" be typed where some allowed just "ed". Some of the options and commands may vary by applications but in general they stay the same.
Similar Threads
  • beginner, programchoise?
    • Amanda96
    • January 14, 2020 at 11:13 AM
    • Kawasaki Robot Forum
  • Teach mode Program GO
    • saberlars
    • April 12, 2020 at 4:58 AM
  • Error 896 - Option not set up
    • Smajic Jasmin
    • July 6, 2019 at 3:40 PM
  • Manual for creating a base in a very old C40F-A Kawasaki controller
    • robotecnik
    • June 7, 2019 at 8:09 AM
  • How to modify Position Variable
    • Ethan Nash
    • May 24, 2019 at 8:16 PM
  • Kawasaki UX150 A55 Help required to return to life
    • Nzhuhu
    • July 10, 2018 at 2:13 PM
  • 3D printing with a Kawasaki UX120 C series controller
    • Nortech
    • August 25, 2018 at 8:11 PM
  • Edit AS language programe
    • sydat95
    • July 5, 2018 at 1:22 PM
  • Kawasaki RS05L + E71 controller
    • Tomasz
    • May 21, 2016 at 12:57 PM
  • AS language
  • offline programming
