How to write a wait function
  • Hello guys,
    I am rather new to KUKA programming. I want to write a WAIT FOR function so that if it's going to take more than a certain time, an Error be declared. Something like this:
    WaitLoop1:
    $TIMER_STOP[1]=TRUE
    $TIMER_FLAG[1]=FALSE
    $TIMER[1]=-10000
    $TIMER_STOP[1]=FALSE
    WAIT FOR ($IN[7] OR $TIMER_FLAG[1])
    $TIMER_STOP[1]=TRUE
    CONTINUE
    IF $TIMER_FLAG[1]== TRUE THEN
    MyAlarm(7)
    GOTO WaitLoop1
    My problem is that, I want to make it as a function or subprogram so that I could easily use it many times in my program. The inputs of this function should be : the IO number (input or output flag)
    In fact, I don't want the IO value as input, I want the IO number as input. Not just as a number, but also to recognize if its input or output or a flag.
    Can anyone help?
  • It should work to pass the Boolean (Input, Flag, CycFlag, Output) as an :OUT argument.
    WaitForBool ($IN[1])
    WaitForBool ($CYCFLAG[1])
    WaitForBool ($OUT[1])
    DEF WaitForBool(FI_bBoolean :OUT)
      DECL BOOL FI_bBoolean
      $TIMER[1] = -10000
      $TIMER_STOP[1] = FALSE
      WAIT FOR FI_bBoolean OR $TIMER_FLAG[1]
    END
  • Why is that?
    DEF WaitForBool(sig:out)
    DECL BOOL sig
    WAIT FOR sig OR TIMER_LIMIT(10.0)
    IF sig THEN
    ; It was completed due signal
    ELSE
    ; it was completed due timer
    ENFIF
    END
  • Completely true. I was focusing on the TIMER_LIMIT/$TIMER_FLAG and overlooked the signal itself. I guess that there might be some situation though that the signal is TRUE but goes FALSE before the next instruction is evaluated which will be a nice example of Murphy's law.
      $TIMER[1] = -10000
    END
    I have used this method. But for negative signals it seems that it is not possible. I mean like: WAIT FOR NOT $IN[1]
    WaitForBool(NOT $IN[1]) , will not take the not value of $IN[1] address.
    Therefore, it seems that the only chance is to define two subprogram or use CYCFLAG like:
    $CYCFLAG[1]=NOT $IN[1]
    WaitForBool() or WaitForBool($CYCFLAG[1])
    I think by using CYCFLAG then it is not the matter to define an input for the subprogram or not because the CYCFLAG is always valid.
    Is this method true?
  • $CYCFLAGs are always handy for this, although most programmers usually save them for when they need complex Boolean equations evaluated as simple BOOLs -- for Triggers and Interrupts, most often.
    A fancier version of WaitForBool in that example could have additional arguments, like so:
    • Helpful
    it must be variable when using OUT parameter...
    since using OUT parameter transfer, you cannot just use expression or invert condition like:
    WaitForBool(NOT $IN[25])
    or
    WaitForBool($IN[25]==FALSE)
    but ...
    you can modify sub to simply have additional parameter. that additional parameter can be made optional so when not specified, it defaults to certain value
    DEF WaitForBool(sig:out, val:in)
        DECL BOOL sig,val
        IF VarState("val")<>#initialized then
           val=TRUE ; assume TRUE
        ENDIF
        WAIT FOR sig==val OR TIMER_LIMIT(10.0)
    END
