Running Motoman XRC programs on RoboDK
  • samuelRosenberg
  • May 24, 2020 at 12:06 PM
  • samuelRosenberg
    I'm quite new to programming robots, so I thought getting familiar with it using RoboDK, might come useful.
    I'm trying to upload a program to RoboDK, but I think the coordinates are some numbers that the robot generates internally, since they were input using manual teach.
    My question is: how can you convert those coordinates to something that RoboDK (and myself) might be able to understand?
    Example:
    the program generates these position parameters:
    C00001=-57186,-50714,-32217,-8816,-103803,37118
    BC00001=218969
    and then uses it in the program as so:
    MOVJ C00001 BC00001 VJ=20.00
    can someone please explain me the logic behind it? I also tried going through the programming guide, but no luck there.
    Thanks!:thumbs_up:
  • Robodoc
    56
    7
    1,062
    • May 24, 2020 at 2:07 PM
    When you make a program in a Yaskawa robot you record the six encoder values at each position. The C00001=...... are the six encoder positions for the the robot. The six numbers are in order, the six axis of the robot S/L/U/R/B/T. The BC00001=.... is the base axis the robot is on.
    In the program each motion command (MOVJ, MOVL...) moves to the corresponding positional data at the speed programmed. So,
    "MOVJ C00001 BC00001 VJ=20.00"
    is really moving the robot in Joint motion type to encoder values S:-57186,L:-50714,U:-32217,R:-8816,B:-103803,T:37118 and the base axis to 218969 at a velocity of 20%.
    Robodoc
  • samuelRosenberg
    • May 24, 2020 at 2:11 PM
    Thanks Robodoc for the quick reply.
    Is there a way to decode the encoder values? how can I use absolute coordinates instead?
    Best Regards,
    Sam
  • Robodoc
    56
    7
    1,062
    • May 24, 2020 at 3:13 PM
    For real life X/Y/Z position data you need the purchased option of relative job.
    Robodoc
  • XRC
