KSS version 8.6
To make use of the timers in the area Display>Variable>Timer I have to use a system variable in KRL:
$TIMER_STOP[1]=FALSE
$TIMER[1]=0
$TIMER_STOP[1]=TRUE
But for the counters there is no such thing. How do I make a counter value show up in there?
EDIT: Found a thread from 2014 where "panic mode" gives an answer
how to use system counter in KRC2?
"variable shown in Variable monitor as COUNTER is actually I[]"
And he also suggests to use Display>Variable>Single for the purpose of monitoring a value.
There seems to be a way to monitor custom groups of variables
Display > Variable > Overview
Set up Variable Overview - Configmon
I will look into the subject and write a summary to help future generations.
Thank you,
