Load Data Determination - "no identification of load data"
  • joRobot
  • April 23, 2020 at 7:37 AM
  • joRobot
    8
    I have a problem with Kuka Load Data Determination. I run the procedure with an approx. 5 kg tool (standard dimensions, center of mass clearly in the positive Z direction of the flange). After the load determination procedure has finished with no errors, the following information messages are displayed:
    1)-"Identified center of gravity in Z axis is negative"
    2)-"No identification of load data"
    And no load data is calculated to be saved (all the data fields are empty)
    The robot is KR16R2010 C4
    LoadDataDetermination 6.2.8
    KSS 8.3.38
    The smartPad screenshot of messages is in the attachment.
    I tried the procedure more than 20 times with no success. I tried to reinstall LDD from Workvisual, restarting the controller and nothing works. I also tried choosing different versions of KR16R2010 robot, but failed again.
    Does anyone know what could be the problem?
    Images
      • 98.53 kB
      • 509 × 890
      • 44
  • hermann
    404
    2,595
    • April 23, 2020 at 1:05 PM
    The load data determination with loads lower than a third the nominal load often fails.
    Did You enter the load manually? If not, try that.
  • panic mode
    1,267
    13,033
    • April 23, 2020 at 3:06 PM
    Quote from joRobot
    why keep on trying same thing? it sure sounds like a dead end and even after 2000000 times, there would be nothing different.
    it is much better to just read the manual. reading it once should be enough. plus it is very short. what Herman suggested is on page 28, chapter 6.4.
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • April 23, 2020 at 3:23 PM
    I do not know Kuka at all, but are you supposed to enter any armloads prior to doing your load determination? Like ABB robots. I have seen many set up incorrectly because of failure to enter armloads.
  • panic mode
    1,267
    13,033
    • April 23, 2020 at 3:33 PM
    One can always set weight (kg] manually before running LDD (LoadDataDetermination).
    If Load (weight) is sufficient, this is not needed, LDD can accurately determine values of mass, CoG, inertia and inertia axes on it's own.
    But when load is small (relative to robot rated payload), results are inaccurate.
    This has nothing to do with the robot brand, it applies to any measurement system.
    Kuka LDD simply does not discard strange results or assume that load is small. it tells it as it is and lets user deal with it.
    But most people are too lazy to check the documentation or do anything that requires some sort of effort (like typing in value manually) and expect system to magically come up with optimal solution no matter how odd/unfavourable physical setup really is.
  • joRobot
    8
    • April 23, 2020 at 10:29 PM
    I read the manual. The load is 5 kg so it is more than 20% of the rated payload (16 kg). I even tried with a heavier tool. Nothing worked.
    Quote from hermann
    Thank you for sharing your experience hermann.
  • panic mode
    1,267
    13,033
    • April 23, 2020 at 11:28 PM
    is the MADA correct and not ceiling version for example?
    another thing to check is if robot mounted securely (bolted down to a stiff base). for example trying to run LLD while robot is just sitting on the floor on it is on a transport skid is not good. also anything mounted on the robot should be secured properly.
    unfortunately neither LDD6.x not LDD7.x documentation include any troublehsooting.
    it is quite easy to create toool that does have CoG with negative Z value. not sure why such result would get rejected assuming that is the problem.
    can you post photo of the EOAT or any info on approximate shape/size and materials used (or their density)?
  • load data determination
  • kuka tool
