Configuring the "Offline Programming System" KUKA.OfficePC
  • paranoidandroid
  • April 22, 2020 at 7:05 PM
  • paranoidandroid
    26
    Hey all,
    KSS:8.5.8
    Robot: Virtual robot, OfficePc
    Newly acquired, think maybe we're missing a setting in the WoV configuration to virtualize the robot. System's looking for actual RDC connections and all.
    Anyone know which configuration has to change to make this a "dummy" robot?
    Thanks,
    -PA
    panic mode
    1,280
    13,085
    • April 22, 2020 at 7:16 PM
    must be used system and someone replaced HDD or dumped image from a robot.
    should just change envirnment to OfficePc...
    open C:\KRC\Roboter\Config\System\Common\ConfigXml.xml and change
    <Environment EnvPath="Cabinet/"/>
    into
    <Environment EnvPath="Office/"/>
  • massula
    204
    8
    1,427
    • April 22, 2020 at 7:17 PM
    Did You used the WorkingProject that came with OfficePC, or downloaded another project inside it?
    Never used these new OfficePCs, but I think You should configure only the bus connected to it, if is any.
  • paranoidandroid
    26
    • April 22, 2020 at 7:39 PM
    massula, Just using the WoV project it was shipped with. InitialProject, 0.0.0.
    panic mode That fix worked, thank you!
  • Configuration
  • OfficePC
  • offline programming
