Hi all,
How would I write the code in Karel to have the robot move to a position register?
MOVE TO PR[1] doesn't seem to work in Karel. Is there some code I need preceding this?
Thank you,
Brian
Hi all,
Thank you,
Brian
How did you declare/define this PR[ ]?
Sometimes in Karel you may have some problems if you do not inform the complete PR[ ] info (XYZ position, RPW orientation and configuration).
But also, when I programmed karel I used diferent variables of position, maybe PR[ ] is only for TP programs, but I have to check it.
According to Fanuc , motion in Karel is a deprecated function. They are recommending all motion be done in TP programming.
You must have the position data entered in the Position Register before the robot will move to that position.
