  4. ABB Robot Forum
determine which motion command was last executed
  • MIRobotGuy
  • April 7, 2020 at 8:12 PM
  • MIRobotGuy
    8
    34
    I am working on a rapid monitoring module and I am trying to determine which robtarget (or motion instruction) was last commanded by the robot. Is there some data in the robot to get this information directly? or is there an instruction such as "GetDataVal" with a switch that can pull this information?
    Many Thanks,
    MiRobotGuy
    MI Robot Guy
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • April 8, 2020 at 2:03 PM
    You could use TriggL or TriggJ to set a value like a group output (can be sim group) for each motion. Or make your own MyMove routine into which you pass a value to set a num value.
  • MIRobotGuy
    8
    34
    • April 8, 2020 at 2:26 PM
    Hello Lemester68,
    Do you have an example of a "MyMove" routine?
    Thank You,
    MiRobotGuy
    MI Robot Guy
  • Lemster68
    295
    2,454
    Blog Articles
    7
    • April 8, 2020 at 5:35 PM
    Finally found it:
    https://forums.robotstudio.com/discussion/com…8#Comment_27258
  • MIRobotGuy
    8
    34
    • April 8, 2020 at 5:43 PM
    Thanks!
    MI Robot Guy
  • SAABoholic
    21
    5
    550
    • April 9, 2020 at 3:24 PM
    May I ask what the purpose of this is ?
    While you could create your own "MyMove" instructions, or you can take it another level and create "ghost" instructions that is an exact duplicate of the original but with your own code inserted to allow you to do this tracking... the downside is that you're now also responsible to do all the error handling which is usually a royal PITA and with your own instructions (non standard) you're also dealing with the programming aspects of things.
    So, while you're solving your initial problem, you have created multiple others.
    If this is meant to be in an production environment I for one would find other ways.
    Additionally, with this approach the read-ahead might (most likely will) trick your "tracker" since it'll show the last robtarget "read" not necessarily which one is the current one being addressed by the motion planner.
  • monitoring
  • destination position
Users Viewing This Thread
  • 1 Guest
