Initialization of working directory xxx failed
  • I am trying to commission a 2nd hand robot. I can connect to the robot via KLI and can browse and retrieve projects, but when I go to the "Programming and diagnosis" workspace and try to add a connection to the robot, I get an error message "Initialization of working directory <hostname> failed". The "Downloading Files" window flashes briefly beforehand.
    (Hopefully) Relevant info:
    I believe that at one point I did have a working connection in the programming and diagnosis workspace and I deleted it, when I wrongly thought I needed to when swapping from one robot to another.
    Tried in WorkVisual 6.0.3 and 5.0.10 with fresh installs of both and in 6.0.3 on another laptop
    Tried running as administrator
    I have full access and control of C:\Users\myUserName\Documents\WorkVisual 5.0\Repositories
    Windows 7 64bit
    KRC4 controller and KR120 R3200 PA Robot
    Version 8.3.14.105
    I have tried with an SSD from another robot
    Possibly relevant info:
    This robot was bought at the same time as another, and in the process of recommissioning a lot of things got swapped. I believe the configuration I have at the moment has the SSD and robot matched, but inside the wrong cabinet (although it is the same type)
    There are options on the robot that I do not have installed (and ultimately don't need)
    Cell Id does not match Robot Id (I can't remember if that's normal or not, but that was the reason I deleted the original connection, thinking it was remembering the other robot)
  • well.... is the directory name for <hostname> valid? any special characters etc? what language your OS and WoV use?
    i purposely deleted content of Repository directory, refreshed cell, placed checkmark next to controller then inKRC Explorer selected Load files from controller. Everything was normal and i got all files in repository.
  • My username has a period "." in it ("name.DOMAIN"). Other than that no special characters. Robot name is Letters/numbers/dashes.
    Everything is set to English(American).
    I don't believe workvisual has a problem with the period because it happily saves and loads projects in my documents folder.
    Just for kicks, I changed the path in Options to point to a different folder (USB root folder) and changed the naming convention and get the same error. "Initialization of the working directory Test failed"
  • that should make no difference, in fact there is a dot in preceeding folder (5.0).
    something weird is going on. can you show where exactyl you click when message pops up?
    and can you show screenshot of the message?
