Motoman Decimal Data for Alarms
  • Dreamawake
  • April 3, 2020 at 3:42 AM
  • Dreamawake
    14
    Good Morning/Afternoon all,
    hope this message finds you all in good spirits and healthy during these trying times.
    Just a quick question, I can't find anything that references the decimal data brought up in this alarm in any of our Yaskawa Motoman manuals onsite or online.
    We are using a UP50 XRC Motoman if this helps as well as Robotmaster V7 for our offline programming.
    Essentially what's happening is: I was trialing a new offline program for a Robot we just set up (I believe it is using C-Var code due to having problems with P-Var code). The first 3 MovJ's worked fine and looked super nice. However in both programs (we run a side 1 and side 2 program where the robot travels a rail) once it reached the fourth MovJ movement, an alarm popped up.
    The Alarm is as follows:
    "ALARM 4404
    ARITHMETIC ERROR
    [7]
    Occur times: 1"
    I know what Alarm 4404 is, it's described as "The controller error in the path operation process" but I can't find ANY information referring to the decimal data of [7]. Everything I find references Decimal Data 8 through to 10 but nothing prior.
    Any help will be greatly appreciated.
    Thank you all kindly and be safe out there :smiling_face:
  • Motouser
    39
    288
    • April 3, 2020 at 9:11 AM
    I face this alarm when the robot reaches a position but during the travel pass near a singularity.
    The controller stops the robot coz the velocity and acceleration will go up too fast.
  • gustinmi
    • April 3, 2020 at 10:55 AM
    Did you tried to read AlarmSubcode. It might give you a way to interpret what is wrong. Refer to your RC Maintanence manual, section Alarm Layout. From alarm layout:
    1: Alarm code You have 4404
    2: Alarm data Additional value
    3: Alarm type Hint how to interpret value
    6: Sub code data additional
    information character strings
    7:Sub code data character strings
    As far as AlarmData is concerned, there are multiple options. To give you just some :
    0 : No alarm
    1 : Decimal UNSIGNED SHORT type
    (display example: [1])
    2 : UNSIGNED CHAR bit pattern
    (display example: [0000_0001])
    3 : User axis type (display example: [SLURBT])
    4 : Spacial coordinate type (display example: [XYZ])
    5 : Robot coordinate type
    (display example: [XYZRxRyRz])
    6 : Conveyor characteristic file (display example: [123])
    8 : Control group type
    (display example: [R1R2S1S2])
    robot & station
    9 : Decimal SHORT type (display example: [-1])
    10 : UNSIGNED SHORT bit pattern
    (display example: [0000_0000_0000_0001])
    11 : Control group type (display example: [R1])
    for robot only
    12 : Control group type (display example:[R1S1B1])
    for robot, station and base
    20 : Control group LOW/HIGH logical axis
    (display example: [R1:LOW SLURBT, HIGH
    SLURBT])
    21 : Control group MIN/MAX logical axis
    (display example: [R1: MIN SLURBT, MAX
    SLURBT])
    22 : Control group MIN/MAX spacial coordinate
    (display example: [R1: MIN XYZ, MAX XYZ])
    23 : Logical axis of both control group 1 and control
    group 2
    (display example: [R1: SLURBT, R2: SLURBT])
    24 : Logical axis 1 and 2 of the control group
    (display example: [R1: SLURBT, SLURBT])
    25 : Logical axis of the control group and UNSIGNED
    CHAR type
    (display example: [R1: SLURBT, 1])
    27 : Control group and UNSIGNED CHAR type
    (display example: [R1: 1])
    Regards , mg
  • XRC
  • Decimal Data
  • Alarms
  • alarm 4404
  • [7]
  • offline programming
  • robotmaster
