Dear All,
Does anybody have a guide how to set up FTP to IRB6400 M97A controller?
I would like to be able to transfer programs from the PC to the M97A controller
Thank you
Dear All,
Thank you
You can't.
Back then you needed an additional Ethernet board and if my memory serves me right it only supported NFS, plus the robot was a client, so you had to run an external server which the robot connected to.... no transferring of programs TO the robot.
The cool thing was that you also could run a BootP server and cold-boot the robot via the network, which usually took ~5 min (with modified install scripts to eliminate the questions) compared to probably 30min or more with the old floppy way.
Hi SAABoholic,
Thanks for your reply.
My Robots have the ethernet board installed
I have win 10 PC with services for NFS enabled which is connected to a netgear switch and I can connect the robot to this also,
How do I connect between PC & Robot for example is there a similar command as connecting to another PC - \\192.168.x.x\c$
Thanks.
Hi,Shane100Irish
You can use Total Commander software with this configuration:
Session: your favorite name
Host name [:Port]:192.168.125.1
User name: abb
Pass:007
Local dir.: your favorite path on your PC
Here are the parameters for a M97A running BW3.0 that had an exterior mounted S4C-PC.
Besides the DSQC336, it came with the RAP and Ethernet Services options.
SIO:CFG_1.0:3:0::
COM_PHY_CHANNEL:
-Name "sio1:" -Type "sio" -Baudrate 19200
-Name "sio2:" -Type "sio" -Channel 2
-Name "eth1" -Type "ethernet"
COM_TRP:
-Name "tcp/ip" -Type "TCP/IP" -PhyChannel "eth1"\
-LocalAdress "192.168.100.2"
COM_APP:
-Name "rap1" -Type "RAP" -Trp "tcp/ip" -SpSysEvent 1\
-ServerAddress "192.168.100.1" -EnableSUBSCW 1
-Name "nfs" -Type "NFS" -Trp "tcp/ip" -ServerAddress "192.168.100.1"\
-LocalPath "pc:" -ServerPath "/c"
Hi Rainman, Hi Skooter,
Thank you for your advice
I will begin to work with these parameters.
Has anyone used the ABB 3HAC041840-001 S4 S4C, S4C+ Robot Controller Floppy Drive to USB Kit?
Would you recommend?
Thank you
What FTP client are you using?
I have used the Floppy to USB unit also. Very useful because you can set up 99 floppy ids from Floppy0 to Floppy99.
I usually but the dystem disks into Floppy1 to whatever number there are, and store the programs and parameters on Floppy0
Hi All,
Would anybody have either of the options below for RW3.0 S4C?
Opt. 543/128-1 Ethernet Services FTP part no 3HAC034439-001
Opt. 536/128-1 Ethernet Services NFS part no 3HAC034440-001
Thank you
Shane
This is the option 536 folder from disk 8 from the 3HAB2390-2.54 S4C BW3.0 disk pack The other non-arcware disk pack did not have it. Hope it helps.
Thanks Skooter
What is the best way to install it?
Pretty sure it needs to be an authorized option in the KEY file to load it.
If so, you need to do a backup and then an I-Start (press 147 at restart) to load the option.
