Does ROBOGUIDE simulate also reducer usage?
  • Hello robot people!
    Do you know whether the Fanuc Roboguide simulator does compute the reducer wear when running a simulation?
    I've been running a simulation of a very intensive application for few hours and the reducer life is not changing in the page MENU-STATUS-AXIS-DIAG
    diglo
  • It is an addin you select when you install roboguide, but if select the collect reducer info option, you can then examine the wear estimates in the profiler.
  • Hello
    I've also the 3 check box "Collect...." greyed while "collect profile data " is checked.
    If you have an idea of what's going wrong, it will be very hepful
