  4. Comau Robots
COMAU External call of master job
  • Silverstamp
  • March 30, 2020 at 5:07 PM
  • Silverstamp
    95
    Hi everybody,
    Would anybody help me on executing a call of master job from an external I/O?
    Is there any special port/address/input for such function?
    Regards, and thanks in advance!:winking_face:
  • Vladarius
    10
    94
    • April 7, 2020 at 2:08 PM
    Can you describe more about you want to achieve?
  • Silverstamp
    95
    • April 20, 2020 at 7:58 PM
    Hi Vladarius, thanks for replying.
    I want to know how to make the robot activate and reset a certain program.
    Al least in Motoman, you select a program and give it the property of MASTER. Then there is this special dedicated input (EXTERNAL MASTER JOB CALL) that
    calls this program and put the cursor at the top of it. So you know that after an external start command, you will be running your
    jobs from a known starting point, which is in fact, written for this special puspose.
    I cannot find a way of giving any program this special characteristic of MAIN or MASTER, neither I can find a dedicated input that accomplish this two
    tasks: CALL a main predifined program and RESET it.
    $GI() inputs don't list any of the forementioned functionalities.
    I'd appreciate any help.
  • Vladarius
    10
    94
    • April 23, 2020 at 8:44 AM
    Hello Silverstamp
    I don't kwon if you help something from this:
    In comau you can do these things:
    In Menu/Setup/System/Startup you can put your startup.cod program.
    Create your main.cod program with your things
    and in startup.cod program write
    SYS_CALL('ML', 'UD:\\usr\\main.cod') -- command for load from disk to memory main program
    SYS_CALL('PA', 'main') -- command for activation main program
    do cold restart
    when you in auto mode press drire and start main program will activate
  • Silverstamp
    95
    • April 24, 2020 at 4:49 AM
    Quote from Vladarius
    Hello Silverstamp
    do cold restart
    Hi Vladarius,
    I'm very happy to receive help from you, but I still cant find the way of doing this Memory Load and then Program Activation of the startup program by means of external inputs.
    To be more practical: Suppose the robot stops because of an alarm. The operator solves the issue down in the robot area. Then he wants to resume the job from where the robot stopped, then it is simple: from the external master source (plc) you simply give the Drive On command, and then the Start command.
    But, now assume you dont want to resume the job. You drive the arm to the HOME pos and then you want to call main.cod and do the usual start procedure. Here is the question, are you supposed to cold restart to call main? Or do you need to do it manually from the TP? I guess that there is a way of mapping some input to a sys_call procedure to call main, I mean, you give a 1 to an external input going from plc to robot, there the robot deactivates the whatever job is activated, then resets it, and then loads main, and activates main., for finally do Drive ON and Start..
    I hope it's not confusing.
    Thanks again Vladarius!
  • Vladarius
    10
    94
    • April 27, 2020 at 2:45 PM
    You can use external input to $DI and make in robot nohold program where when is this DI true then Deactivate MAIN.cod and Activate MAIN.cod.. it resets main program.. i hope you need something like that..
  • Silverstamp
    95
    • April 27, 2020 at 9:38 PM
    Exactly. But how to I link a $DI to a nohold program, so when the input turns ON, the nohold program executes, no matter what other program is activated or running?
    Thanks Vladarius.:thumbs_up:
  • Vladarius
    10
    94
    • April 28, 2020 at 6:26 AM
    here is code for reset program...
    --$PROP_REVISION:$
    --$PROP_TITLE:$
    --$PROP_HELP:$
    --$PROP_VERSION:3.11.004$
    --$PROP_DATE:2020-04-27 14:35:18$
    --$PROP_AUTHOR:VLADIMIR$
    --$PROP_HOST:C5G_2226877$
    --$PROP_UVL:0$
    --$PROP_UML:0$
    PROGRAM reset NOHOLD
    BEGIN
    CYCLE
    WAIT FOR $DIN[1]+ -------wait for digital imput 1 from false to true
    DEACTIVATE MAIN ------- deactivate main program... program must have name main.cod and must be in memory
    ACTIVATE MAIN ------ activate main .. program will start over..
    END reset
  • Vladarius
    10
    94
    • April 28, 2020 at 7:10 AM
    And one thing.. if you don't have free hardware digital input you can make vitual device in io_cnfg / network and put digital inputs/outputs there...
    Images
      • 17.21 kB
      • 800 × 480
      • 5
  • Silverstamp
    95
    • May 4, 2020 at 3:57 PM
    --$PROP_REVISION:$
    --$PROP_TITLE:$
    --$PROP_HELP:$
    --$PROP_UVL:0$
    --$PROP_UML:0$
    BEGIN
    CYCLE
    END reset
    Hi Vladarius!:smiling_face:
    Thanks again for your help. This code is great because it's simple and clear, but, I still don't realize how, if you have another program activated and running, this program would react to the digital input if it's not activated and running first?
    I wonder if there is a way of making this job run cyclically and could be left that way and at the same time start and run main other sub routines, so when DIN[1] is activated main is deactivated as wished by the operator.
    Regards
  • Vladarius
    10
    94
    • May 5, 2020 at 12:00 PM
    • #11
    That program will cycle.. there is command cycle after begin.. and this nohold program will run allways and running in background just load him in prog .. it will have green circle.. that means the program is running.. it is simple program just waiting for din 1 signal.. and deactivating and activating resets the main program.. just try it and let me know..
    Images
      • 125.87 kB
      • 1,920 × 1,080
      • 8
  • Silverstamp
    95
    • May 5, 2020 at 8:15 PM
    • #12
    Vladarius, you're just great! Thank you very much.
    I'll let you know when I've tried this out.
    Hope I could give some help back..:smiling_face:
  • Silverstamp
    95
    • May 5, 2020 at 9:43 PM
    • #13
    Vladarius,
    I've tried on Robosim and worked fine. It is just what I was looking for. In Motoman these programas are called System Jobs, due to the can run in parallel with motion jobs. Also Motoman has a ladder that runs continuously in the back, where you can make further logic, which runs faster,
    I wonder if Comau has a ladder to. As far as I know, there is nothing like that.
    Thanks again!
  • Vladarius
    10
    94
    • May 6, 2020 at 6:40 AM
    • #14
    Im glad i helpt.
    In COMAU you can make these background programs calld nohold even with graphics and your own icon on teach pendant... For example we created whole software for comau robot to control welding source LORCH because official comau has no support for this brand.. or software for control conveyor belt without plc .. belt is controlled direct from robot etc..
    here is one more example from youtube.. robot direct control schneider lexium32 drive via profinet..
    /watch?v=iL993HtH1To
  • Silverstamp
    95
    • May 6, 2020 at 7:06 PM
    • #15
    Great Vladarius, very nice porject. Did you integrated the Lexium32 to the C5G CPU or you are sending commands to the driver?
  • massula
    200
    8
    1,421
    • May 6, 2020 at 10:26 PM
    • #16
    Nice trick with the jog button.
  • Vladarius
    10
    94
    • May 8, 2020 at 7:37 PM
    • #17
    Quote from Silverstamp
    Thank you,
    Yes.. communication is via profinet and on c5g is running nohold program for controlling.. even you can have your own commands in IDE editor program like run motor on position or run with specific velocity etc..
  • Silverstamp
    95
    • May 15, 2020 at 7:47 PM
    • #18
    Thank you,
    I guess that sync with the arm is not possible, I mean as an alternative to a standard 7h axis?
  • Master
  • main program
  • top of master
  • external call
