KUKA VKRC1 - it´s MFC card ?
  • Hello,
    I have KUKA robot VW VKRC1 from Volkswagen automotive.
    Year 2000.
    In controller is MFC card, but she have different connector.
    Right is standard connector X2: Sub-D, 26-contact.
    But left is not standard MFC 5 pin connector. Here is Sub-D 9 pin.
    I can´t nowhere find any documentation whether this is a normal MFC card and how to connect it to certain pins on the left connector.
    Does anyone have experience with this?
    Thank you,
  • Hello this card version MFC 1.06 for KRC1
    MFC 1.08 and upwards using Phoenix contact Combicon 5 Pole connector and it is for devicenet communication.
    MFC 1.06 using DB9 connector and without power supply pins for devicenet.
    Pins:
    2. CAN-
    3. Drain
    7. CAN+
    Do not connect termination resistor externally on 1.06 MFC because already equipped in the board.
  • Thank you very much for your help.
    My robot controller is standard VW and he haven´t battery inside for normal program ending and shutdown.
    The controller shuts down hard and is cold start every time it is turned on.
    Can I connect the batteries to this VW controller as is the standard controller ?
    They are connected to the two lower pins of the X202 connector inside.
    Or can something be destroyed and the controller is not adapted to it ?
    Thank you.
  • As far as I can recall, the VKRC1 used exactly the same batteries as the KRC1, wired in identical fashion. You should simply be able to buy a new set of replacement batteries and install them properly. Messing with the internal connections is not advisable.
