RJ3iB restore backup from Boot menu not working
  • I have a RJ3iB that has hangs on a controlled start. I have a full controller backup (not image) that I am trying to restore. When I try to use the boot monitor (press F1 and F5 while cycle power) to do a backup restore it clears the sram but doesn't load the backup files. the message reads "loaded 0 files" and goes back to the boot menu.
    I tried doing an init start but it still hangs during the following controlled start.
    Of course I don't have the original system software and the F# isn't licensed so Fanuc tech support won't help.
    anyone have any ideas?
    Blade
  • Well, you probably should have had an image backup. A file backup won't do much good now.
    Can you post a screenshot of what backup files you do have? Also are they at the top level in your flash drive or memory card, not in a folder?
