Advertising
SKILLSND Instruction
  • Hi, what does the following statement mean?
    What functions does it have?
    Where can I find instructions on this?
    SKILLSND "LGETPOS LT:0 B0:1 B1:2"
    GETARG LB000 IARG#(1)
    SET LB001 0
    SET LB002 2
    GETARG LB004 IARG#(2)
    GETARG LB005 IARG#(3)
    SET P[LB004] LP000
    SET B[LB005] LB003
  • It's a MACRO.
    You can see its contruction on the macro list.
    It has 3 arguments LT,B0 and B1 that where stored in LB000, LB004 and LB005 that are 3 local variables (visible only in the job used).
    The 2nd arguments seems to be used to create a position (it indicates in which Pxxx I will put the value stored in LP000) and the 3rd to create a B variable (it indicates in which Bxxx will be stores the value of LB003).
    I don't see the rest of the macro nor the job in which is used so I can only conjecturing.
    Edited 3 times, last by Motouser ().
