Hello
I had got question from my boss if is possible use Weintek screen on kuka krc4 connected via profinet. On the screen will be some informations about number of actually program, number of pieces atc...
Hello
Well, that depends.
Does your robot have Profinet? Does this screen support Profinet? Can you get a normal GSD file for the screen? If so, then you can probably use these two together without much trouble.
After a short view on the Weintek site: it seems to be impossible, not one word about profinet. You should ask Weintek direct.
how about using OPC? you can add OPC UA server to your KRC4 and it looks like this HMI can use it too..
I'm going to testing....
Thanks for your answers
