Hello
In some documents and pictures i see there are master tool in P-Variables but i couldn't find it in our controller and in motosim. Can any person say how can we active master tool and see it?
Best Regards
Hello
Best Regards
You have to have the coordinated motion software option turned on. When you calibrate a robot to another robot or a robot to an external axis the master tool frame will be available.
what is it and when must we use it?
What is different between it and normal tool?
How can define it same as normal tools?
Display Morewhat is it and ?
The controller, when initialized, knows everything about the external axis or the other robot except where is it in relation to the 1st robot. Calibrating the two pieces of hardware together tells the controller where the external axis is in X, Y, X, Rx, Ry, and Rz from the robot. The calibration process creates the master tool frame. This will be a right hand rule with the Z-axis centered and extending out of the faceplate.
when must we use it
When you are doing coordinated motion. The two pieces of hardware can not move accurately without the calibration being done. Can be used for shifting or jogging on a user frame that rotates with the external axis.
Only coordinate system that uses it is synchronous jogging.
Is defined with three points instead of five. Same concept, three points taught around a common point.
Thank you.
After enabling 027 COORDINATED INSTRUCTION and 132 EXTENDED CONTROL GROUP options in YRC1000 how to make and use MASTER TOOL in MotoSim EG-VRC ? I haven't found it in docs.
if you are doing it with real robot, just import cmos.bin into motosim
Motosim is the only what I have at the moment. I'm learning yaskawa robots and trying to make a master tool user coordinates
Once you get your hardware in place. The software can create the master tool frame based on layout. It maybe the controller tab, file setting, and then robot calibration. I’m assuming your using MotoSim EG-VRC and not MotoSim EG.
As far as a master tool user coordinate ( if this means a user frame that rotates with the master tool frame) that is an option. You can not turn it on in MotoSim EG-VRC. This would be turned on in the real controller and be in the cmos when loaded into the virtual controller.
Thank you. The further I go with yaskawa the more surprises I get. I've spent a lot of time trying to get master tool. I wonder why yaskawa decided to restrict that feature, I thought it's a standard offline feature.
P.S. May be MotoPlus could also be turned on on MotoSim EG-VRC by uploading cmos.bin from the real hardware controller?
No, Motoplus couldn't active with upload cmos.bin file. It can only work on real robot.
The feature isn't restricted. A small percentage of people use this.
You have to have multiple pieces of hardware on the controller.
You need to have coordinated motion turned on.
