Hi everybody,
I have a problem opening programs in IDE mode on Comau Robots with C4G software.
All programs from startup was load,but i cannot open the programs.
What could be the reason for this message?
I
Hi everybody,
I
Probably syntax errors.
Try to open these programs with WinC4G, make small edits, and save them again.
It there are some syntax errors, WinC4G will war You about them.
Hi Massula,
I saved all programs with COD file and there wasn't any errors. My C4G SW version is 3.35 a read this info from TP.
My C4G library is also 3.35 - this is info from WIN C4G.
Could it be with this problem?
Hi, sirmant15.
I don't think so. If.the WinC4G library and robot software version are matching, the problem must be another thing.
When you go to the IDE panel on the C4G controller, try giving it time to load all the interface on the pendant before selecting a program. I had a similar issue on a C4G piston stuffer robot a few years ago. The more programs loaded the longer it will take, so I suggest open the Program pane and wait 10 minutes or more.
