Hello All
I request your help to provide me a project file from TwinCat3 where the external start interface is programmed to start the KUKA robot as slave.
Since we are ( myself and the PLC programmer) are not aligned in this topic and after explaining with the signal flow diagram available at KSS8.3 document, I felt it would make the process much easier if there is a preprogrammed Twincat 3 project file is available.
We are currently struggling in the following process.
1. Restart a robot process after a ramp stop
2. Error Handling. ($CONF_MESS)
3. Error Handling for a PLC(Master) - (Slave)KRC4(Master)-(Slave)Gripper-Festo
Thank you in advance for your support.
