Verify a position configuration in program Fanuc
  • fan123
  • March 5, 2020 at 2:59 PM
  • fan123
    In a Fanuc program, is there a way to know a position's configuration (P or PR)?
    The same as "IF (PR[21,1] = 20)..." for the X coordinate, but for the nofiguration in order to diferentiate a NUT000 from a NUT001
    It's a little bit a continuation of this thread : Change Configuration of a PR[] in Program
    Thank's in advance
  • Nation
    Typical Robot Error
    544
    1,924
    • March 5, 2020 at 4:18 PM
    It doesn't appear like there is a way, in TP at least. You could write a small Karel program to do the compare, and then call it from TP. This is assuming you have the Karel option of course.
  • fan123
    • March 5, 2020 at 6:26 PM
    Thanks for your answer !
    I have the option, but i've never used it.
    Could you give me an example ? (I'll read a little bit about the karel after)
    Edit: I didn't want to use Karel, but if i am going to, could you add the way to also edit the NUT000 into a NUT001 and vice versa in karel ?
    Edited once, last by fan123 (March 5, 2020 at 6:31 PM).
  • TitusLepic
    112
    7
    442
    • March 6, 2020 at 12:36 AM
    Here's a program that will read the number of turns from a PR (PR[16] in this case), print that value to the user screen, then change the number of turns to 1. I think this demonstrates everything you asked about.
    PROGRAM CONFIGDEMO
    VAR
        myPos    :    XYZWPREXT
        myPR    :    INTEGER
        noTurns    :    INTEGER
        STATUS    :    INTEGER
    BEGIN
        myPR =16
        myPos = GET_POS_REG(myPR,STATUS)
        noTurns = myPos.CONFIG_DATA.CFG_TURN_NO3
        WRITE TPDISPLAY(noTurns, ' Turns', CR)
        myPos.CONFIG_DATA.CFG_TURN_NO3 = 1
        SET_POS_REG(myPR,myPos,STATUS)
    END CONFIGDEMO
  • HawkME
    568
    3,268
    • March 6, 2020 at 3:41 AM
    Very interesting topic. But I'd like to ask what you are wanting this for? There may be a simpler solution.
    For example, Linear moves will ignore turn numbers and take the shortest path. Joint moves will honor the turn number, but if you do Joint MROT (minimum rotation) then you will get a joint move that ignores the turn number.
  • fan123
    • March 9, 2020 at 11:22 PM
    Thank you for your example @TitusLepic, we did something similar and it's functioning perfectly.
    @HawkME , Actually its for a palletizing program, and I wanted to have only one program and one set of points for 2 mirrored layers, and then use offsets and config to do *mirror* movements in the mirrored layer.
    With linear moves I had to much turns for some drops. (seems to always turn the same direction when its from a 180)
    I tested the MROT quickly, but as i have 3 drops per pick with different orientations (i.e. J6 = 0, 90, 180), the faster way to return is sometime a +180 = 360 instead of a -180 = 0(same as linear ??), and that is why I don't think I can use it here.
    What do you think about it ?
  • HawkME
    568
    3,268
    • March 10, 2020 at 2:17 AM
    It sounds like you are wanting to command a specific turn number while doing a linear move. If that's the case then Linear Wjnt may work for you. It combines a linear move with exact turn numbers. It is not as fool proof as the Karel method, but is simple.
  • fan123
    • March 10, 2020 at 10:27 PM
    It didn't work well either (But I might test it more thoroughly with my next program..), so I am going on with the Karel method this time.
    That helped me a lot. Thanks again !
Similar Threads
  • Cubic-S, Thoughts/Opinions/Best Practices
    • ericwiz7923
    • March 2, 2020 at 2:04 PM
    • Kawasaki Robot Forum
  • Query for Operating in Tool Coordinates - Fanuc 200ic
    • PGUK
    • October 1, 2019 at 5:09 PM
    • Fanuc Robot Forum
  • fanuc programming
