SSD in Kuka KRC2 Robot
  • Counterspeller
  • March 4, 2020 at 12:41 PM
  • Counterspeller
    102
    Hello guys!
    Is it possible for me to use an SSD on the KPC of KUKA KRC2 robots? If so, how do I make your connections?
    Thanks for any help.
    panic mode
    1,278
    13,079
    • March 4, 2020 at 1:26 PM
    • Best Answer
    Its been a while that HDD was replaced by SSD on KRC2 as well. Connections are same regardless of different inner workings. Contact KUKA for quote and provide system info.
  • Counterspeller
    102
    • March 4, 2020 at 1:46 PM
    Quote from panic mode
    Okay, I contacted kuka, they provide the SSD but they do not provide the adapter for normal HD to SSD, my intention was to exchange the normal HD I have in the one robot for an SSD, have you ever done something like that? Because even the kuka didn't know how to inform me about it.
    SkyeFire
    1,051
    9,423
    • March 4, 2020 at 1:58 PM
    What generation of KRC2 do you have?
    What connection does the original hard drive have?
    What connection does the SSD have?
    panic mode
    1,278
    13,079
    • March 4, 2020 at 2:52 PM
    SSD and HDD have same interfaces. both can have either PATA or SATA.
    older KPCS used PATA and SSD for KRC2 also have PATA.
    SSD for KRC4 have SATA.
    sounds as if you are trying to connect SSD with SATA to a KPC with PATA interface.
    such adapters do exist and are easily found in any computer store.
    HDD/SSD need to be recognised by the BIOS or it will not boot so if you are doing some DIY, you will need to try and see what works and how.
  • Counterspeller
    102
    • March 5, 2020 at 11:42 AM
    Quote from SkyeFire
    The Generation is ed2005 with XP win.
    Atual connection of the hard drive:
    SSD Connection:
  • Counterspeller
    102
    • March 5, 2020 at 11:46 AM
    Yes, I have a Robot HD with an IDE interface and I want to adapt it to SATA.
  • dexterv
    16
    110
    • March 5, 2020 at 12:39 PM
    You need a converter, there are plenty to choose from.
  • TadeuFerraz
    17
    • March 9, 2020 at 12:12 PM
    Hello everyone.
    Was there a significant improvement with this change? can you describe them?
  • Counterspeller
    102
    • March 18, 2020 at 11:49 AM
    Quote from Counterspeller
    SSD Connection:
    Panic mode or Skyefire, i have to use a converter for this, right? If I pass the image from normal HD to SDD I will need to reconfigure the bios, but I never did anything like that, could you two who are very experienced in relation to kuka robots can help me?
    SkyeFire
    1,051
    9,423
    • March 18, 2020 at 1:51 PM
    • #11
    I don't think any BIOS changes should be needed, as long as the converter still makes the new SSD appear as Drive C to the motherboard. In this respect, a KRC is no different from a regular PC.
    https://www.bleepingcomputer.com/forums/t/57421…de-motherboard/
    One thing to keep in mind is that PATA/IDE isn't as "smart" as SATA, so you'll probably have to ensure you set the Master/Slave jumpers on the IDE/SATA converter correctly.
  • Counterspeller
    102
    • March 24, 2020 at 3:06 PM
    • #12
    Quote from SkyeFire
    Thanks SkyeFire, you are best.
  • Andy_rus
    21
    • March 25, 2020 at 5:53 PM
    • #13
    SSD on the KRC2 system work OK, need SATA <-> IDE converter. I use Agestar converter ( http://www.agestar.com/en/Products/Co…idge-board.html )
  • info555
    • May 1, 2021 at 2:12 PM
    • #14
  • Event Robotics
    8
    62
    • May 2, 2021 at 9:20 AM
    • #15
    You can use these ssd's.
    Just replace your hdd for the ssd in the cradle and format it.
    Then put your image from the original hdd on it and have fun with it.
    Works like a charm.
Similar Threads
  • Another (V)KRC2 to KRC2 thread
    • AndreasA
    • March 17, 2019 at 10:39 AM
    • KUKA Robot Forum
  • RSI with KRC2 - Robot Not Moving
    • rrobot92
    • February 27, 2020 at 4:38 PM
    • KUKA Robot Forum
  • KUKA KRC2 control via Xbox PS4 gamepad
    • Tomek155
    • January 8, 2020 at 10:24 PM
    • KUKA Robot Forum
  • How often do you master a KuKa robot
    • ktmf
    • March 3, 2020 at 11:42 AM
    • KUKA Robot Forum
  • post processor kuka krc1
    • bastien diligent
    • January 29, 2020 at 1:22 PM
    • KUKA Robot Forum
  • inaccuracy Kuka KRC2
    • Francisco
    • February 19, 2020 at 10:59 PM
    • KUKA Robot Forum
  • Teach Pendant Screen Black for a KRC2
    • tbarnes
    • February 15, 2020 at 2:00 AM
    • KUKA Robot Forum
  • KUKA KRC2 OfficeLite 5.2.OL FLEXlm License Finder
    • EngineerTex
    • December 17, 2019 at 5:23 PM
    • KUKA Robot Forum
  • KRC2 ed05 KSS 5.2.21 update to KSS 5.6.10
    • jancsi
    • December 10, 2019 at 6:31 AM
    • KUKA Robot Forum
  • krc2
    • sirine haffar
    • April 4, 2018 at 1:44 PM
    • KUKA Robot Forum
