TCP calibration
  • why not pick point that is in center and flush with suction cups? this way you most likely only need to add distance from flange (tool Z). and if you would like to make Z pointing up so that Z+ lifts the robot tool regardless of used coordinate system, you can add rotations too (B 180).
    so, perhaps if Z is 450mm your tool would be something like
    tool_data[1]={X 0, Y 0, Z 450, A 0, B 180, C 0}
    next you need to setup load for that tool
